Sandisk SSD Ext 4TB Extreme Portable USB-C
Quicklinx: H4DYWS00 Mfr#: SDSSDE61-4T00-G25
More than 50 In Stock
£520.46 ex VAT
£624.55 inc VAT
Your life's an adventure. The SanDisk Extreme Portable SSD fits your mobile lifestyle and accelerates every move. Nearly 2x as fast as the previous generation!
  • Powerful yet portable
    Get fast NVMe solid state performance in a portable, high-capacity drive that's perfect for creating amazing content or capturing incredible footage.
  • Tough enough to take with you
    Up to two-meter drop protection and IP55 water and dust resistance mean this durable drive can take a beating.
  • It goes where you go
    Use the handy carabiner loop to attach the drive to your belt loop or backpack for extra security when you're out in the world.
  • Put a lock on your files
    Help keep private content private with the included password protection featuring 256-bit AES hardware encryption.
  • Professional-grade storage
    From SanDisk, the professional photographers worldwide trust to handle their shots and footage.
SanDisk Extreme Portable V2 - SSD - 4 TB - USB 3.2 Gen 2
Solid state drive - external (portable)
4 TB
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2
Water resistant, dust-proof, NVM Express (NVMe)
Enclosure Colour
52.42 mm x 100.54 mm x 8.95 mm
52 g
5-year warranty
4 TB
256-bit AES
USB 3.2 Gen 2
52.42 mm
100.54 mm
8.95 mm
52 g
Performance
Internal Data Rate
1050 MBps (read) / 1000 MBps (write)
Expansion & Connectivity
1 x USB 3.2 Gen 2
Windows 8, Apple MacOS X 10.9 or later, Windows 10
1 x USB-C to USB-C cable - external , 1 x USB-C to USB-A adapter - external
FCC, ICES, IP65, RCM, BIS, UKCA, CE/EAC
Enclosure Colour
Limited warranty - 5 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Shock Tolerance (operating)
1500 g
Vibration Tolerance (operating)
5 gRMS @ 10-2000 Hz
Brand: Sandisk
Price Range Ex VAT: £500 - £750
