Your life's an adventure. The SanDisk Extreme Portable SSD fits your mobile lifestyle and accelerates every move. Nearly 2x as fast as the previous generation!
Powerful yet portable
Get fast NVMe solid state performance in a portable, high-capacity drive that's perfect for creating amazing content or capturing incredible footage. -
Tough enough to take with you
Up to two-meter drop protection and IP55 water and dust resistance mean this durable drive can take a beating. -
It goes where you go
Use the handy carabiner loop to attach the drive to your belt loop or backpack for extra security when you're out in the world. -
Put a lock on your files
Help keep private content private with the included password protection featuring 256-bit AES hardware encryption. -
Professional-grade storage
From SanDisk, the professional photographers worldwide trust to handle their shots and footage.
- SanDisk Extreme Portable V2 - SSD - 4 TB - USB 3.2 Gen 2
- Solid state drive - external (portable)
- Capacity
- 4 TB
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.2 Gen 2
- Water resistant, dust-proof, NVM Express (NVMe)
- Enclosure Colour
- Black
- 52.42 mm x 100.54 mm x 8.95 mm
- 52 g
- 5-year warranty
- Capacity
- 4 TB
- 256-bit AES
- Interface
- USB 3.2 Gen 2
- 52.42 mm
- 100.54 mm
- 8.95 mm
- 52 g
Performance
- Internal Data Rate
- 1050 MBps (read) / 1000 MBps (write)
Expansion & Connectivity
- 1 x USB 3.2 Gen 2
- OS Required
- Windows 8, Apple MacOS X 10.9 or later, Windows 10
- Cables Included
- 1 x USB-C to USB-C cable - external , 1 x USB-C to USB-A adapter - external
- FCC, ICES, IP65, RCM, BIS, UKCA, CE/EAC
- Enclosure Colour
- Black
- Limited warranty - 5 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Shock Tolerance (operating)
- 1500 g
- Vibration Tolerance (operating)
- 5 gRMS @ 10-2000 Hz
