Sandisk SSD Ext 1TB Extreme Pro Portable USB-C
Quicklinx: HMLZWS00 Mfr#: SDSSDE81-1T00-G25
40 In Stock
£196.32 ex VAT
£235.58 inc VAT
Creating top-tier content can put a strain on your device, your camera or your system. To capture and keep your best work, you need fast, high-capacity storage that's reliable enough to help you consistently overdeliver on your toughest jobs. The SanDisk Extreme PRO Portable SSD is housed in a forged aluminum chassis that also acts as a heatsink, saving you time through higher sustained speeds - up to 2000MB/s read and 2000MB/s write. A durable silicon shell, up to two-meter drop protection, IP55 water and dust resistance, and a handy carabineer loop for securing the drive give you the peace of mind to take it with you wherever your job - or life - takes you. From the brand trusted by professional photographers worldwide, the SanDisk Extreme PRO Portable SSD provides solid state performance in a rugged, dependable storage solution.
  • Blazing-fast performance
    SanDisk Extreme Pro provides full-frame editing with little interruption while saving you time and keeping your computer's internal storage free. You'll be able to edit right from the drive.
  • Ruggedized design with purpose-built materials
    Ruggedized design with a forged aluminum body to protect the SSD core and dissipate heat. Plus, a durable silicon rubber coating seeks to deliver higher impact resistance with its IP55 rating for water and dust resistance.
  • Lightweight and pocket sized
    The small and light form factor of the Extreme PRO SSD means it couldn't be easier to keep your content with you whether you're crossing town or traveling to an international location.
SanDisk Extreme PRO Portable V2 - SSD - 1 TB - USB 3.2 Gen 2x2
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2x2 - USB-C
Data Transfer Rate
20 Gbps (USB 3.2 Gen 2x2)
Water resistant, dust-proof, NVM Express (NVMe)
57.34 mm x 110.26 mm x 10.22 mm
5-year warranty
Intel Next Unit of Computing 13 Extreme Kit - NUC13RNGi7
1 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2x2
57.34 mm
110.26 mm
10.22 mm
Performance
Interface Transfer Rate
Internal Data Rate
2000 MBps (read) / 2000 MBps (write)
Expansion & Connectivity
1 x USB 3.2 Gen 2x2
Windows 8, Apple MacOS X 10.9 or later, Windows 10
1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
IP55
Limited warranty - 5 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Shock Tolerance (operating)
1500 g
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Brand: Sandisk
