The rugged SanDisk Extreme Portable SSD delivers high-speed transfers with up to 550MB/s read speeds. This makes it perfect for saving and editing hi-res photos and videos. With an IP55 rating, it also stands up to rain, splashes, spills and dust.
Up to 550MB/s read speeds
With high-performance transfers with up to 550MB/s read speeds, the SanDisk Extreme Portable SSD lets you offload files in a snap. -
Works with Windows and Mac, USB-C or USB-A
Designed to work with both Windows and Mac, the SanDisk Extreme Portable SSD is equipped with a USB 3.1 Type-C connector and also includes a USB Type-C to Type-C cable and a Type-C to Type-A adapter, meaning it will work with the PCs and Macs of today, tomorrow and yesterday. -
Compact, pocket-sized design
Good things come in small sizes! The SanDisk Extreme Portable SSD delivers high-performance and capacity in a drive that's smaller than a smartphone.
- SanDisk Extreme Portable - SSD - 1 TB - USB 3.2 Gen 2
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.2 Gen 2
- Data Transfer Rate
- 10.0 Gbps (USB 3.2 Gen2)
- Water resistant, dust-proof
- 52.42 mm x 100.54 mm x 8.95 mm
- Localisation
- Australia, Latin America, Asia Pacific, Middle East, Africa, Europe, Americas
- 5-year warranty
- Capacity
- 1 TB
- 256-bit AES
- Interface
- USB 3.2 Gen 2
- 52.42 mm
- 100.54 mm
- 8.95 mm
Performance
- Interface Transfer Rate
- Internal Data Rate
- 1050 MBps
Expansion & Connectivity
- 1 x USB 3.2 Gen 2
- OS Required
- Apple MacOS X 10.6 or later, Windows 8, Windows 8.1, Windows 10
- Cables Included
- 1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
- IEC 60529 IP55
- Localisation
- Limited warranty - 5 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Shock Tolerance (operating)
- 1500 g
- Vibration Tolerance (operating)
- 5 gRMS @ 10-2000 Hz
