Sandisk SSD Ext 1TB Extreme Portable USB-C
Quicklinx: GLMFWS00 Mfr#: SDSSDE61-1T00-G25
More than 50 In Stock
£76.61 ex VAT
£91.93 inc VAT
The rugged SanDisk Extreme Portable SSD delivers high-speed transfers with up to 550MB/s read speeds. This makes it perfect for saving and editing hi-res photos and videos. With an IP55 rating, it also stands up to rain, splashes, spills and dust.
  • Up to 550MB/s read speeds
    With high-performance transfers with up to 550MB/s read speeds, the SanDisk Extreme Portable SSD lets you offload files in a snap.
  • Works with Windows and Mac, USB-C or USB-A
    Designed to work with both Windows and Mac, the SanDisk Extreme Portable SSD is equipped with a USB 3.1 Type-C connector and also includes a USB Type-C to Type-C cable and a Type-C to Type-A adapter, meaning it will work with the PCs and Macs of today, tomorrow and yesterday.
  • Compact, pocket-sized design
    Good things come in small sizes! The SanDisk Extreme Portable SSD delivers high-performance and capacity in a drive that's smaller than a smartphone.
SanDisk Extreme Portable - SSD - 1 TB - USB 3.2 Gen 2
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Water resistant, dust-proof
52.42 mm x 100.54 mm x 8.95 mm
Australia, Latin America, Asia Pacific, Middle East, Africa, Europe, Americas
5-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2
52.42 mm
100.54 mm
8.95 mm
Performance
Interface Transfer Rate
Internal Data Rate
1050 MBps
Expansion & Connectivity
1 x USB 3.2 Gen 2
Apple MacOS X 10.6 or later, Windows 8, Windows 8.1, Windows 10
1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
IEC 60529 IP55
Limited warranty - 5 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Shock Tolerance (operating)
1500 g
Vibration Tolerance (operating)
5 gRMS @ 10-2000 Hz
Brand: Sandisk
