Sandisk SanDisk Extreme Pro - USB flash drive - 1 TB - USB 3.2 Gen 1
Quicklinx: HMLYWS00 Mfr#: SDCZ880-1T00-G46
17 In Stock
£132.83 ex VAT
£159.39 inc VAT
Custom built for people who need to move huge files fast, the SanDisk Extreme PRO USB 3.2 Flash Drive delivers maximum performance so you can set your own pace.
  • Move huge files fast
    Blazing-fast performance lets you transfer a full-length 4K movie to the drive in less than 15 seconds or 1000 photos in less than 25 seconds.
  • Reliable performance
    Work as fast as you need to with premium performance and huge capacities in a portable yet tough and reliable USB flash drive.
  • Take it with you
    Grab and go without worrying about everyday wear and tear thanks to an elegant yet durable aluminum metal casing.
  • Put a lock on critical files
    Put critical files in a vault folder to help keep them away from prying eyes with SanDisk SecureAccess encryption software.
  • Like an "Undo" for deleted files
    Accidentally deleted important files? Recover them easily with the included RescuePRO Deluxe data recovery software (download required).
  • Work with flexibility
    Convenient backward-compatibly means you can plug this versatile drive into any USB 2.0 or 3.0 port.
USB flash drive
Interface Type
USB 3.2 Gen 1
Storage Capacity
1 TB
Encryption Algorithm
128-bit AES
Software Included
SanDisk RescuePRO, SanDisk SecureAccess
USB flash drive
Storage Capacity
1 TB
128-bit AES
Interface Type
USB 3.2 Gen 1
Password protection, retractable connector, aluminum body
Software Included
11 mm
21 mm
71 mm
18.14 g
Brand: Sandisk
