Sandisk SanDisk Extreme Pro - Flash memory card (microSDXC to SD ada
Quicklinx: HGS7WS00 Mfr#: SDSQXCD-128G-GN6MA
More than 50 In Stock
£39.89 ex VAT
£47.86 inc VAT
Get extreme speeds from a microSDXC memory card for fast transfer, app performance, and 4K UHD. Ideal for your Android smartphone, action cameras or drones, this high-performance Extreme Pro microSDXC card does 4K UHD video recording, Full HD video, and high-resolution photos. Super-fast SanDisk Extreme PRO microSDXC memory card achieves high read and write speeds. Plus, it's A2-rated, so you can get fast application performance for an exceptional smartphone experience.
  • Improve your workflow efficiency
    With SanDisk QuickFlow Technology, this card optimizes performance for timesaving media offloads with quick read speeds.
  • High write speeds
    Capture fast-action photos or shoot 4K UHD video with incredible write speeds. The SanDisk Extreme PRO microSDXC UHS-I card lets you shoot more and faster.
  • Great for capturing 4K UHD video
    Ideal for recording outdoor adventures, weekend trips, or sporting events without skipping frames. With a high capacity, the SanDisk Extreme PRO microSD UHS-I card lets you capture uninterrupted 4K UHD and Full HD video with its UHS Speed Class 3 (U3) and Video Speed Class 30 (V30) ratings.
  • Load apps faster with A2
    Get faster app performance for an outstanding smartphone experience thanks to the SanDisk Extreme PRO microSD card's A25 Specification.
  • Durable design for use in extreme environments
    SanDisk Extreme PRO microSDXC UHS-I cards are shockproof, temperature-proof, waterproof, and X-ray-proof, so you can enjoy your adventures without worrying about the durability of your memory card.
SanDisk Extreme Pro - flash memory card - 128 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
128 GB
Speed Rating
A2 / Video Class V30 / UHS-I U3 / Class10
Included Memory Adapter
microSDXC to SD adapter
Software Included
SanDisk RescuePRO Deluxe, SanDisk Memory Zone
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
128 GB
Speed Class
Read Rate
Up to 200 MB/s
Write Rate
Up to 90 MB/s
Shockproof, waterproof, X-ray-proof, temperature-proof, SanDisk QuickFlow technology
Software Included
Limited warranty - lifetime , Germany: limited warranty - 30 years , Canada: limited warranty - 30 years
14.99 mm
10.92 mm
Thickness
1.02 mm
-25 °C
85 °C
Brand: Sandisk
