                Robust storage capacityWith a spacious 1 TB capacity, this solid state drive accommodates large files including videos, high-resolution images, and extensive projects.
                High-speed performanceAchieve data transfer speeds of up to 2000 MBps, streamlining your workflow and allowing for rapid access to important files.
                Durable designConstructed to withstand adverse conditions, this drive is both water-resistant and dust-resistant, making it a reliable choice for outdoor and on-the-go usage.
                Advanced connectivityEquipped with USB-C and supporting USB 3.2 Gen 2x2 technology, this hard drive delivers quick data transfer rates, enhancing compatibility with modern devices.
                Wide temperature rangeOperates effectively in a range of temperatures, ensuring dependable performance whether in hot or cold environments.
- SanDisk Creator Pro - SSD - 1 TB - USB 3.2 Gen 2x2
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.2 Gen 2x2 - USB-C
- Data Transfer Rate
- 20 Gbps (USB 3.2 Gen 2x2)
- Water resistant, dust-resistant
- 57.83 mm x 110.8 mm x 10.31 mm
- 77.5 g
- 5-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.2 Gen 2x2
- 57.83 mm
- 110.8 mm
- 10.31 mm
- 77.5 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 2000 MBps (read) / 2000 MBps (write)
Expansion & Connectivity
- 1 x USB 3.2 Gen 2x2 - 24 pin USB-C
- Software Included
- Adobe Creative Cloud (1 month membership)
- OS Required
- Windows 10 or later, Apple macOS 14 or later
- Cables Included
- 1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
- IP65
- Shipping Width
- 10.3 cm
- Shipping Depth
- 13.6 cm
- Shipping Height
- 3.45 cm
- Limited warranty - 5 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
