SanDisk Creator Desk Drive - SSD - 4 TB
Quicklinx: J04TWS00 Mfr#: SDSSDT40C-4T00-E25
Hurry, only 1 left in stock!
£253.33 ex VAT
£303.99 inc VAT
Marketing description is not available.
  • Efficient data transfer
    The drive features a USB 3.2 Gen 2 interface with a speed of 10.0 Gbps, allowing for quick data transfers and ease of use.
  • High storage performance
    Designed as an external solid state drive, it offers an internal data rate of 1000 MBps, providing fast access to files and documents.
  • Robust compatibility
    With exFAT formatting, this drive supports various operating systems seamlessly, including compatibility with Apple Time Machine for easy backups.
  • Versatile connection options
    The product includes a USB-C port and comes with both USB-C and USB-C to USB-A cables, making it adaptable to different devices.
  • Suitable for diverse environments
    The drive performs well across a range of temperatures, from -20°C to 60°C for storage and operates efficiently from 0°C to 35°C.
SanDisk Creator Desk Drive - SSD - 4 TB - USB 3.2 Gen 2
Solid state drive - external (desktop)
4 TB
USB 3.2 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Apple Time Machine compatible, exFAT formatted
Power Source
Included AC adapter
Enclosure Colour
Blue gradient
9.91 cm x 9.91 cm x 4.02 cm
249.6 g
3-year warranty
4 TB
USB 3.2 Gen 2
9.91 cm
9.91 cm
4.02 cm
249.6 g
Performance
Interface Transfer Rate
Internal Data Rate
1000 MBps
Expansion & Connectivity
1 x USB 3.2 Gen 2 - 24 pin USB-C
Power Source
Included AC adapter
Software Included
Adobe Creative Cloud (1 month membership)
Windows 10 or later, Apple macOS 10.14 or later
1 x USB-C cable - external , 1 x USB-C to USB-A cable - external
Enclosure Colour
Blue gradient
Shipping Width
13.6 cm
Shipping Depth
22 cm
Shipping Height
6.7 cm
Limited warranty - 3 years
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Brand: Sandisk
