High capacity storage
With 256 GB of storage, this microSDXC card accommodates large files including high-resolution photos, videos, and applications, tailored for creators who require ample space. -
Fast data transfer rates
Achieving read speeds of 190 MB/s and write speeds of 130 MB/s ensures rapid file transfers and optimized performance for multimedia applications and data storage. -
Enhanced durability features
Protected against water, shock, magnetism, X-rays, temperature extremes, drops, humidity, and wear, this memory card is designed to withstand harsh conditions while keeping data safe. -
Improved app performance
The A2 speed class rating allows for seamless app storage and usage, ensuring quick load times and responsive interactions with application data. -
Versatile compatibility
The included microSDXC to SD adapter makes this memory card compatible with a wide variety of devices, offering flexibility for use in cameras, smartphones, and tablets.
 - SanDisk Creator - flash memory card - 256 GB - microSDXC UHS-I
- Product Type
 - Flash memory card
- Form Factor
 - microSDXC UHS-I Memory Card
- Storage Capacity
 - 256 GB
- Speed Rating
 - A2 / Video Class V30 / UHS-I U3
- Included Memory Adapter
 - microSDXC to SD adapter
- Software Included
 - Adobe Photoshop Lightroom (3 months trial)
 - Limited lifetime warranty
- Product Type
 - Flash memory card
- Storage Capacity
 - 256 GB
- Speed Class
- Read Rate
 - Up to 190 MB/s
- Write Rate
 - Up to 130 MB/s
- Form Factor
 - Temperature-proof, magnetic-proof, waterproof, shockproof, wear-out proof, X-ray-proof, drop-proof, humidity-proof
- Software Included
 - Limited warranty - lifetime
 - 10.92 mm
 - 14.99 mm
 - 1.02 mm
 - 0.26 g
