                High-speed performanceWith a read rate of 280 MB/s and a write rate of 100 MB/s, this SDXC UHS-II memory card enables quick access and efficient data transfers, ideal for multitasking and heavy file usage.
                Versatile compatibilityDesigned to work seamlessly with various devices, this memory card accommodates a wide range of applications, making it suitable for both amateur and professional creators.
                Dedicated write protectionEquipped with a write protection switch, this memory card prevents accidental overwriting of files, ensuring the integrity of your data with simple functionality.
                Generous storage capacityThe 128 GB storage capacity provides ample room for storing high-resolution videos, images, and documents, making it a practical choice for content creators.
                Reliable speed classClassified as Video Class V60 and UHS-II U3, this memory card delivers the performance required for recording high-quality video content without interruptions.
- SanDisk Creator - flash memory card - 128 GB - SDXC UHS-II
- Product Type
- Flash memory card
- Form Factor
- SDXC UHS-II Memory Card
- Storage Capacity
- 128 GB
- Speed Rating
- Video Class V60 / UHS-II U3 / Class10
- Software Included
- RescuePRO Deluxe (2 years download), Adobe Creative Cloud (1 month membership)
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 128 GB
- Speed Class
- Read Rate
- Up to 280 MB/s
- Write Rate
- Up to 100 MB/s
- Form Factor
- Write protection switch
- Software Included
- Limited warranty - lifetime
- 24 mm
- 32 mm
- 2.1 mm
- 1.67 g
