Robust storage capacity
With 1 TB of space, this memory card allows users to store an extensive library of high-resolution photos, videos, and important files without needing frequent replacements. -
High-speed performance
The read rate of 280 MB/s and write rate of 150 MB/s facilitate smooth data transfer, making it ideal for high-definition video recording and rapid editing workflows. -
Convenient write protection
The integrated write protection switch prevents accidental data loss, ensuring that files remain secure during transport and use. -
Versatile compatibility
Compatible with various devices, this SDXC UHS-II memory card supports a wide range of applications, catering to both casual users and professionals.
 - SanDisk Creator - flash memory card - 1 TB - SDXC UHS-II
- Product Type
 - Flash memory card
- Form Factor
 - SDXC UHS-II Memory Card
- Storage Capacity
 - 1 TB
- Speed Rating
 - Video Class V60 / UHS-II U3 / Class10
- Software Included
 - RescuePRO Deluxe (2 years download), Adobe Creative Cloud (1 month membership)
 - Limited lifetime warranty
- Product Type
 - Flash memory card
- Storage Capacity
 - 1 TB
- Speed Class
- Read Rate
 - Up to 280 MB/s
- Write Rate
 - Up to 150 MB/s
- Form Factor
 - Write protection switch
- Software Included
 - Limited warranty - lifetime
 - 24 mm
 - 32 mm
 - 2.1 mm
 - 1.67 g
