Your world is bigger than any one device, and your life spans across your entire device ecosystem. Effortlessly integrate your USB Type-CTM devices with the SanDisk® Phone Drive. Create with confidence with capacities up to 1TB(1), providing ample space for your photos and videos. Connect to your compatible USB Type-CTM iPhones, iPads, and Mac computers for quick and easy file transfers at rapid speeds up to 150MB/s(2). Designed to match your iOS lifestyle, this drive features an elegant silhouette and premium exterior.
Enhance your device ecosystem
Specifically built for USB Type-C™ devices, the SanDisk® Phone Drive with USB-C™ allows you to effortlessly transfer photos and videos across your compatible iPhone, iPad, MacBook, and more.
Keep creating, not deleting
Expand your iPhone’s storage with up to 1TB* of extra space, for more high-res photos, more high-def videos, and more important files.
Relive your moments
With data recovery, your precious memories are protected so you can keep enjoying the moment.
Captivatingly crafted
The SanDisk® Phone Drive is a polished extension of your style and sensibility, with four hues designed for your compatible iPhone 16’s look.
Preserve your favorite content
Automatically back up and manage files with the included SanDisk® app (iPhone and iPad only).
(1) 1GB=1,000,000,000 bytes. 1TB=1,000,000,000,000. Actual user storage capacity less.
(2) Based upon read speed, unless otherwise stated. 1MB/s = 1 million bytes per second. Based on internal testing; performance may vary depending upon host device, usage conditions, drive capacity, and other factors. USB 3.0 port required.
