The SanDisk Fortnite Peely Edition USB flash drive combines playful design with high-performance functionality. Offering a storage capacity of 128 GB, it is designed to cater to the needs of gamers who require ample space for their files and game data. With a read rate of 130 MB/s, transferring data is quick and efficient, enhancing your workflow. The convenient key ring loop makes it easy to attach to bags or keychains, ensuring that essential files are always within reach. Whether in a gaming setup or on-the-go, this USB flash drive meets various compatibility needs while providing durability for everyday use.
Robust Performance
With a read rate of 130 MB/s, this USB flash drive ensures efficient and speedy data transfers, making it ideal for gaming and large file storage. -
Spacious Storage
The 128 GB capacity offers enough room for numerous files, applications, and game data, catering to the storage needs of any user. -
Durable Design
Built to withstand everyday use, this flash drive features a sturdy construction that can handle various environments, making it reliable for all users. -
Easy Portability
The key ring loop adds a layer of convenience, allowing users to easily attach the drive to keychains or bags for on-the-go access to important files. -
Temperature Resilience
Designed to operate between 0 °C and 45 °C, this flash drive provides reliable performance in a range of conditions, ensuring data safety.
- SanDisk Fortnite - Peely Edition - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.2 Gen 1
- Storage Capacity
- 128 GB
- OS Required
- Microsoft Windows 10 or later, Apple MacOS 12.0 or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Read Rate
- Up to 130 MB/s
- Interface Type
- USB 3.2 Gen 1
- Key ring loop
- OS Required
- Limited warranty - 5 years
- 20 mm
- 60 mm
- 9 mm
- 6 g
- 0 °C
- 45 °C
