Sandisk Optimus Eco 800GB SSD 2.5" SAS 6Gb/s
Quicklinx: C4RTWS00 Mfr#: SDLKOCDR-800G-5CA1
The Optimus Eco SSD ushers in a new era of flash storage bringing together a combination of high performance, capacity, endurance and reliability, while using cost-effective 19nm eMLC flash. This combination makes the Optimus Eco SSD the ideal solution for a wide variety of mixed-use application workloads such as Online Transaction Processing (OLTP), Financial Transactions, and E-mail/Messaging, and read-intensive application workloads such as Web Servers, Video on Demand (VOD) and Web-based Applications. The Optimus Eco can be deployed by Cloud service providers or hyper-scale data centers, in existing directly attached, SAN, and NAS storage architectures.
Available in capacities of 400GB - 2TB, the Optimus Eco SSD provides random read/write performance up to 90K/35K IOPS and sequential read/write data transfer rates of up to 530/530 MB/s. The Optimus Eco SSD is dual ported with 1GB/s Read/800 MB/s Write in active/active operation for sequential read/write performance. The Optimus Eco SSD provides 3 random DWPD4. Optimus Eco SSDs have a 5 year warranty.
Guardian Technology Platform
Optimus Eco SAS SSDs are powered by SanDisk’s proprietary Guardian Technology Platform, a comprehensive suite of enterprise features comprised of FlashGuard, DataGuard and EverGuard technologies.
FlashGuard Technology combines Aggregated Flash Management, which treats all flash elements as a single system, and Advanced Signal Processing, which dynamically adjusts flash parameters throughout the life of the SSD, to reliably extract significantly more life from commercial-grade MLC flash, making it suitable for mixed-use application workloads.
DataGuard Technology features full data path protection, safeguarding user data from corruption along all data paths in the SSD.
EverGuard Technology protects against loss of user data in the event of unexpected power interruptions using a 3rd generation backup power circuit design and high reliability discrete capacitors. Optimus Eco SAS SSDs are designed for I/O intensive, mission-critical, 24/7 applications.
  • Guardian Technology Platform
    The Optimus SSD is powered by SanDisk's Guardian Technology Platform, a comprehensive suite of innovative features comprised of FlashGuard, DataGuard and EverGuard technologies.
  • FlashGuard Technology
    FlashGuard Technology extends the native endurance of 19nm consumer-grade MLC flash based SSDs to deliver 3/7 Drive Writes Per Day (random/sequential workload). Optimus Eco SSDs have a five year warranty. FlashGuard Technology combines Aggregated Flash Management, which treats all flash elements as a single system, and Advanced Signal Processing, which dynamically adjusts flash parameters throughout the life of the SSD, to reliably extract significantly more life from the most cost-effective MLC flash, making it suitable for read-intensive application workloads.
  • DataGuard Technology
    DataGuard Technology features full data path protection, safeguarding user data from corruption along all data paths in the SSD. DataGuard Technology also protects the SSD against loss of data at the page and block levels using a unique feature called F.R.A.M.E. (Flexible Redundant Array of Memory Elements). F.R.A.M.E. acts as a data recovery feature that enables the recovery of user data even after catastrophic events such as flash page or block failures.
  • EverGuard Technology
    EverGuard Technology protects against loss of user data in the event of unexpected power interruptions using a 3rd generation backup power circuit design and highreliability discrete capacitors.
SanDisk Optimus Eco - SSD - 800 GB - SAS 6Gb/s
Solid state drive - internal
800 GB
NAND Flash Memory Type
19nm multi-level cell (MLC)
2.5" x 1/8H
SAS 6Gb/s
Data Transfer Rate
600 MBps
FlashGuard Technology, DataGuard Technology, EverGuard Technology, Guardian Technology Platform, built-in backup power circuitry, Flexible Redundant Array of Memory Elements (F.R.A.M.E.)
69.85 mm x 100.2 mm x 9.5 mm
5-year warranty
800 GB
2.5" x 1/8H
SAS 6Gb/s
69.85 mm
100.2 mm
9.5 mm
Performance
Drive Writes Per Day (DWPD)
3
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
530 MBps (read) / 530 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
35000 IOPS
Reliability
MTBF
2,500,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" x 1/8H
Power Consumption
7 Watt (active)
Limited warranty - 5 years
70 °C
5 - 95% (non-condensing)
