Sandisk microSDHC 32GB with microSD to SD Adaptor
SanDisk Standard Imaging Video 1
Quicklinx: 7MJTWS00 Mfr#: SDSDQB-032G-B35
Type: microSDHC
Capacity: 32GB
SD Speed Class: Class 4
£5.19 ex VAT
£6.22 inc VAT
SanDisk microSDHC mobile memory cards are the ideal companion for multimedia phones because they plug right inside the phone providing immediate expansion of memory storage needed for carrying more music, video, photos, games, and mobile software applications in phones.
  • The capacity you need to store more
    Smartphones and tablets can do so much these days that unless you have enough capacity you could be missing out on their capabilities. 32GB SanDisk microSDHC memory cards give you plenty headroom for whatever you need to store, just in case – even if you want to carry hundreds of family photos, hours of videos or a comprehensive selection of your favourite music tracks around with you.
  • Make more of your time out
    SanDisk microSDHC memory cards help store your photos, videos, music and more, so that it is easy for you to share your experiences, memorable moments and favourite tunes with your family and friends.
  • Make more of your work
    Wherever you are, 32GB SanDisk microSDHC memory cards help keep your work to hand so that you can carry on with presentations, spreadsheets and documents at a moment's notice, then share them with colleagues.
  • Keep on using your card anywhere
    SanDisk microSDHC memory cards are designed to be waterproof, temperature-proof, shock-proof and x-ray-proof, so they will keep on working whatever life throws at them.
  • Compatibility
    The 32GB SanDisk microSDHC memory card works with any device that has a microSD card slot.
  • Reassurance with performance
    SanDisk develops and engineers its microSDHC memory cards to maximise reliability, so you can count on your 32GB microSDHC memory card to store your important files.You can live life with total peace of mind. The 32GB SanDisk microSDHC memory cards are backed by a 5-year limited warranty.
SanDisk - flash memory card - 32 GB - microSDHC
Flash memory card
microSDHC
Storage Capacity
32 GB
Speed Rating
Class 4
Enclosure Colour
Latin America, Asia Pacific, Middle East, Africa, Europe
Included Memory Adapter
microSDHC to SD adapter
5-year warranty
Flash memory card
Storage Capacity
32 GB
Enclosure Colour
Speed Class
Class 4
microSDHC
Limited warranty - 5 years
11 mm
15 mm
Thickness
1 mm
0.4 g
Type: microSDHC
Capacity: 32GB
Brand: Sandisk
