Sandisk FC Extreme PRO 128GB SD 200MB CL10
Quicklinx: HRK3WS00 Mfr#: SDSDXXD-128G-GN4IN
More than 50 In Stock
£42.17 ex VAT
£50.60 inc VAT
The powerful SD UHS-I memory card yet delivers performance that elevates your creativity. With shot speeds of up to 140MB/s and UHS speed Class 3 (U3) recording, you're ready to capture stunning high-resolution, stutter-free 4K UHD video. And, because your pace doesn't let up after the shots are in, it delivers up to 200MB/s transfer speeds for a faster postproduction workflow. Plus, it's built to withstand weather, water, shocks and other less-than-ideal conditions so you can rest assured that it's good to go wherever your work takes you.
  • Improve your workflow efficiency
    With SanDisk QuickFlow technology, this card optimizes performance for timesaving media offloads with quick transfer speeds up to 200MB/s.
  • Shot speeds up to 140MB/s
    With shot speeds up to 140MB/s the card is perfect for capturing the action as it happens, without missing a beat.
  • Perfect for 4K UHD video
    Sometimes speed is what you need. The SanDisk Extreme PRO SD UHS-I card delivers the performance to capture stunning, uninterrupted 4K UHD video.
  • Stunning sequential burst mode shots
    Rated UHS Speed Class 3 (U3) and Video Speed Class 30 (V30), the SanDisk Extreme PRO SD UHS-I card lets you capture sequential burst mode shots without missing a beat.
  • Durability you can count on
    Built for and tested in harsh conditions, the SanDisk Extreme PRO SD UHS-I card is temperature-proof, waterproof, shock-proof, and x-ray-proof.
SanDisk Extreme Pro - flash memory card - 128 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
128 GB
Speed Rating
Video Class V30 / UHS-I U3 / Class10
Software Included
RescuePRO Deluxe (2 years download)
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
128 GB
Speed Class
Read Rate
Up to 200 MB/s
Write Rate
Up to 90 MB/s
Shockproof, waterproof, write protection switch, X-ray-proof, temperature-proof
Software Included
Limited warranty - lifetime
Regional Warranty Exceptions
23.91 mm
31.92 mm
2.17 mm
-25 °C
85 °C
Brand: Sandisk
