Sandisk FC Extreme 32GB SD 100MB CL10
Quicklinx: HC5JWS00 Mfr#: SDSDXVT-032G-GNCIN
£23.46 ex VAT
£28.15 inc VAT
The SanDisk Extreme SDHC UHS-I memory card is a robust storage solution designed to meet the needs of photography enthusiasts and professionals alike. With a generous 32 GB storage capacity, it offers ample space for high-resolution images and 4K video recordings. Engineered for durability, it is shockproof, waterproof, and temperature-proof, capable of operating in extreme conditions ranging from -25°C to 85°C. High-speed performance is a hallmark of this memory card, boasting read speeds of up to 100 MB/s and write speeds of up to 60 MB/s, facilitating quick file access and efficient data transfer. Additionally, the inclusion of SanDisk technology enhances the speed and efficiency of file transfers, ensuring optimal performance. For added security, a write protection switch prevents the accidental deletion of files. Its compatibility with a wide range of devices makes it a versatile choice for various photography and videography needs.
  • Improve your workflow efficiency
    With SanDisk QuickFlow technology, this card optimizes performance for timesaving media offloads with quick transfer speeds up to 180MB/s.
  • Shot speeds up to 130MB/s
    With shot speeds up to 130MB/s6 the card is perfect for capturing the action as it happens, without missing a beat.
  • Perfect for 4K UHD video
    Sometimes speed is what you need. The SanDisk Extreme SD UHS-I card delivers the performance to capture stunning, uninterrupted 4K UHD video.
  • Durability you can count on
    Built for and tested in harsh conditions, the SanDisk Extreme SD UHS-I card is temperature-proof, waterproof, shock-proof, and x-ray-proof.
  • Recover images you accidentally deleted
    Includes an offer for RescuePRO Deluxe data recovery software which lets you restore images you accidentally deleted.
SanDisk Extreme - flash memory card - 32 GB - SDHC UHS-I
Flash memory card
SDHC UHS-I Memory Card
Storage Capacity
32 GB
Speed Rating
Video Class V30 / UHS-I U3 / Class10
Software Included
SanDisk RescuePRO Deluxe
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
32 GB
Speed Class
Read Rate
Up to 100 MB/s
Write Rate
Up to 60 MB/s
Shockproof, waterproof, write protection switch, X-ray-proof, temperature-proof, SanDisk QuickFlow technology
Software Included
Limited warranty - lifetime
Regional Warranty Exceptions
24 mm
32 mm
2.1 mm
-25 °C
85 °C
Brand: Sandisk
