The SanDisk Extreme USB Flash Drive packs unparalleled transfer speeds and generous capacity into a pocket-sized package. Boasting data transfer rates up to 190MB/s, this USB flash drive can transfer files up to ten times faster than an ordinary USB 2.0 flash drive. And with up to 64GB of storage capacity, the drive can accommodate all your important personal files and documents. Outfitted with SanDisk's latest flash memory technology, the SanDisk Extreme 3.0 USB Flash Drive dramatically reduces the time you'll spend waiting for files to transfer. Fully enabled for USB 3.0 ports, the drive can achieve transfer speeds of up to 190MB/s, which means even the largest files will transfer in seconds. You'll be able to move and store HD videos, high-resolution photos, and other bulky files in an instant. Featuring a sleek black colour scheme, the SanDisk Extreme USB Flash Drive is as stylish as it is functional. Thanks to the drive's compact, slim design, you can easily slip it into a pocket.
- Exceptional file transfer speeds up to 190MB/s
- Drives up to 64GB can hold your most important data
- Password protection with SanDisk SecureAccess Software
- Includes 2GB of online backup via YuuWaa cloud storage
- USB 3.0 enabled for super-fast transfer speeds
The speed you need for a hectic lifestyle
With write speeds of up to 190MB/s, 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drives are up to 45x faster than standard USB 2.0 drives. It takes a fraction of the time for the 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drive to transfer a full-length movie so that you can start watching it within moments. -
The capacity you want
The 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drive gives you plenty of headroom, just in case, so you can live your life the way you want it. If you need a heavy-duty USB flash drive that can carry tens of thousands of photos, tracks, videos or the large files that you need for work – even video and high resolution images hungry for storage space – then this is the perfect one for you. -
Stylish Performance
When you're using cutting edge technology, you want to know it looks good as well. The 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drive is small enough to hold in the palm of your hand, with a stylish slider design that pops the USB connector out when you want to use it, and protects it when you don't. -
Check Out The Action
The 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drive uses a glowing LED to let you know that the drives are ready for reading or writing data. Once the drive has been inserted into the USB port, the LED pulses when data is being transferred, and slows down when the drives are idle, keeping you up to date on what's happening. -
Stay Protected With SanDisk
SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault, and they'll be protected by a personal password and automatic 128-bit AES encryption. This means that your content will stay private and secure when you are out and about or if you store the drive away for safe keeping. -
Compatibility
The 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drive is optimised for laptops and devices with USB 3.0 ports. It is also backwards compatible with older devices that have USB 2.0 ports, so you can be assured that you can still get the most from them. -
Reassurance With Performance
SanDisk develops and engineers its USB flash drives to maximise reliability, so you can count on your 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drive to store your important files.You can enjoy extreme speed with total peace of mind. The 64GB SanDisk Extreme High-Speed USB 3.0 Flash Drive is backed by a lifetime warranty.
- SanDisk Extreme - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 64 GB
- Encryption Algorithm
- 128-bit AES
- Enclosure Colour
- Black
- Software Included
- SanDisk SecureAccess 3.0
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- 128-bit AES
- Enclosure Colour
- Black
- Read Rate
- Up to 190 MB/s
- Interface Type
- USB 3.0
- Password protection, retractable connector
- Software Included
- OS Required
- 70.87 mm
- 21.34 mm
- 11.43 mm
- 0 °C
- 45 °C
