Sandisk EXTREME PRO MICROSDXC 64GB+SD
Quicklinx: HD98WS00 Mfr#: SDSQXCU-064G-GN6MA
More than 50 In Stock
£24.41 ex VAT
£29.29 inc VAT
This powerful SD UHS-I memory card delivers performance that elevates your creativity. With high shot speeds and UHS speed Class 3 (U3) recording, you're ready to capture stunning high-resolution, stutter-free 4K UHD video. And, because your pace doesn't let up after the shots are in, it delivers high transfer speeds for a faster postproduction workflow. Plus, it's built to withstand weather, water, shocks and other less-than-ideal conditions so you can rest assured that it's good to go wherever your work takes you.
  • Improve your workflow efficiency
    With SanDisk QuickFlow technology, this card optimizes performance for time-saving media offloads with quick transfer speeds.
  • High shot speeds
    With high shot speeds, the card is perfect for capturing the action as it happens, without missing a beat.
  • Perfect for 4K UHD video
    Sometimes speed is what you need. The SanDisk Extreme PRO SD UHS-I card delivers the performance to capture stunning, uninterrupted 4K UHD video.
  • Stunning sequential burst mode shots
    Rated UHS Speed Class 3 (U3) and Video Speed Class 30 (V30), the SanDisk Extreme PRO SD UHS-I card lets you capture sequential burst mode shots without missing a beat.
  • Durability you can count on
    Built for and tested in harsh conditions, the SanDisk Extreme PRO SD UHS-I card is temperature-proof, waterproof, shock-proof, and x-ray-proof.
SanDisk Extreme Pro - flash memory card - 64 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
A2 / Video Class V30 / UHS-I U3 / Class10
Latin America, Asia Pacific, Middle East, Africa, Europe
Included Memory Adapter
microSDXC to SD adapter
Software Included
SanDisk RescuePRO Deluxe, SanDisk Memory Zone
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
64 GB
Speed Class
Read Rate
Up to 200 MB/s
Write Rate
Up to 90 MB/s
Shockproof, waterproof, X-ray-proof, temperature-proof
Software Included
Limited warranty - lifetime
Regional Warranty Exceptions
14.99 mm
10.92 mm
Thickness
1.02 mm
4.54 g
Shipping Width
152 mm
Shipping Depth
4.9 mm
Shipping Height
101 mm
Shipping Weight
13.76 g
Brand: Sandisk
