Sandisk EXTREME PRO 1TB SDXC MEMORY
Quicklinx: HL9QWS00 Mfr#: SDSDXXD-1T00-GN4IN
£152.51 ex VAT
£183.01 inc VAT
The SanDisk Extreme Pro SDXC UHS-I memory card redefines the limits of storage and speed for photography and videography enthusiasts. Offering 1 TB of storage capacity, it accommodates extensive libraries of high-resolution images and videos. Engineered for efficiency, it features read speeds of up to 200 MB/s and write speeds of up to 140 MB/s, supported by SanDisk QuickFlow technology for faster data handling and optimal performance. This memory card is not just about speed and space; it's built to endure. With its shockproof, waterproof, temperature-proof, and X-ray-proof design, it stands up to demanding environments, ensuring your data is always protected. Additionally, the inclusion of a write protection switch means you're in full control, preventing accidental deletion of your precious memories. Whether you're capturing the natural world, documenting life's milestones, or creating content, the SanDisk Extreme Pro is your reliable partner for storing and accessing your creative work.
  • Improve your workflow efficiency
    With SanDisk QuickFlow technology, this card optimizes performance for timesaving media offloads with quick transfer speeds up to 200 Mbps.
  • Shot speeds up to 140 Mbps
    With shot speeds up to 140 Mbps the card is perfect for capturing the action as it happens, without missing a beat.
  • Perfect for 4K UHD video
    Sometimes speed is what you need. The SanDisk Extreme PRO SD UHS-I card delivers the performance to capture stunning, uninterrupted 4K UHD video.
  • Stunning sequential burst mode shots
    Rated UHS Speed Class 3 (U3) and Video Speed Class 30 (V30), the SanDisk Extreme PRO SD UHS-I card lets you capture sequential burst mode shots without missing a beat.
  • Durability you can count on
    Built for and tested in harsh conditions, the SanDisk Extreme PRO SD UHS-I card is temperature-proof, waterproof, shock-proof, and x-ray-proof.
SanDisk Extreme Pro - flash memory card - 1 TB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
1 TB
Speed Rating
Video Class V30 / UHS-I U3 / Class10
Software Included
RescuePRO Deluxe (2 years download)
Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
1 TB
Speed Class
Read Rate
Up to 200 MB/s
Write Rate
Up to 140 MB/s
Shockproof, waterproof, write protection switch, X-ray-proof, temperature-proof, SanDisk QuickFlow technology
Software Included
Limited warranty - lifetime , Germany: limited warranty - 30 years
24 mm
2.1 mm
32 mm
-25 °C
85 °C
Brand: Sandisk
