This powerful SD UHS-I memory card delivers performance that elevates your creativity. With high shot speeds and UHS speed Class 3 (U3) recording, you're ready to capture stunning high-resolution, stutter-free 4K UHD video. And, because your pace doesn't let up after the shots are in, it delivers high transfer speeds for a faster postproduction workflow. Plus, it's built to withstand weather, water, shocks and other less-than-ideal conditions so you can rest assured that it's good to go wherever your work takes you.
Improve your workflow efficiency
With SanDisk QuickFlow technology, this card optimizes performance for time-saving media offloads with quick transfer speeds. -
High shot speeds
With high shot speeds, the card is perfect for capturing the action as it happens, without missing a beat. -
Perfect for 4K UHD video
Sometimes speed is what you need. The SanDisk Extreme PRO SD UHS-I card delivers the performance to capture stunning, uninterrupted 4K UHD video. -
Stunning sequential burst mode shots
Rated UHS Speed Class 3 (U3) and Video Speed Class 30 (V30), the SanDisk Extreme PRO SD UHS-I card lets you capture sequential burst mode shots without missing a beat. -
Durability you can count on
Built for and tested in harsh conditions, the SanDisk Extreme PRO SD UHS-I card is temperature-proof, waterproof, shock-proof, and x-ray-proof.
- SanDisk Extreme Pro - flash memory card - 256 GB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 256 GB
- Speed Rating
- A2 / Video Class V30 / UHS-I U3 / Class10
- Included Memory Adapter
- microSDXC to SD adapter
- Software Included
- SanDisk RescuePRO Deluxe, SanDisk Memory Zone
- Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
- Product Type
- Flash memory card
- Storage Capacity
- 256 GB
- Speed Class
- Read Rate
- Up to 200 MB/s
- Write Rate
- Up to 140 MB/s
- Form Factor
- Shockproof, waterproof, X-ray-proof, temperature-proof
- Software Included
- Limited warranty - lifetime ¦ Germany: limited warranty - 30 years ¦ Canada: limited warranty - 30 years
- 14.99 mm
- 10.92 mm
- Thickness
- 1.02 mm
- -25 °C
- 85 °C
