Sandisk Extreme Pro - Flash memory card (microSDXC to SD ada
Quicklinx: H2NHWS00 Mfr#: SDSQXCD-256G-GN6MA
12 In Stock
£61.70 ex VAT
£74.04 inc VAT
This powerful SD UHS-I memory card delivers performance that elevates your creativity. With high shot speeds and UHS speed Class 3 (U3) recording, you're ready to capture stunning high-resolution, stutter-free 4K UHD video. And, because your pace doesn't let up after the shots are in, it delivers high transfer speeds for a faster postproduction workflow. Plus, it's built to withstand weather, water, shocks and other less-than-ideal conditions so you can rest assured that it's good to go wherever your work takes you.
  • Improve your workflow efficiency
    With SanDisk QuickFlow technology, this card optimizes performance for time-saving media offloads with quick transfer speeds.
  • High shot speeds
    With high shot speeds, the card is perfect for capturing the action as it happens, without missing a beat.
  • Perfect for 4K UHD video
    Sometimes speed is what you need. The SanDisk Extreme PRO SD UHS-I card delivers the performance to capture stunning, uninterrupted 4K UHD video.
  • Stunning sequential burst mode shots
    Rated UHS Speed Class 3 (U3) and Video Speed Class 30 (V30), the SanDisk Extreme PRO SD UHS-I card lets you capture sequential burst mode shots without missing a beat.
  • Durability you can count on
    Built for and tested in harsh conditions, the SanDisk Extreme PRO SD UHS-I card is temperature-proof, waterproof, shock-proof, and x-ray-proof.
SanDisk Extreme Pro - flash memory card - 256 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
256 GB
Speed Rating
A2 / Video Class V30 / UHS-I U3 / Class10
Included Memory Adapter
microSDXC to SD adapter
Software Included
SanDisk RescuePRO Deluxe, SanDisk Memory Zone
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
256 GB
Speed Class
Read Rate
Up to 200 MB/s
Write Rate
Up to 140 MB/s
Shockproof, waterproof, X-ray-proof, temperature-proof
Software Included
Limited warranty - lifetime , Germany: limited warranty - 30 years , Canada: limited warranty - 30 years
14.99 mm
10.92 mm
Thickness
1.02 mm
-25 °C
85 °C
Brand: Sandisk
