The rugged SanDisk Extreme Portable SSD delivers high-speed transfers with up to 550MB/s read speeds. This makes it perfect for saving and editing hi-res photos and videos. With an IP55 rating, it also stands up to rain, splashes, spills and dust.
Up to 550MB/s read speeds
With high-performance transfers with up to 550MB/s read speeds, the SanDisk Extreme Portable SSD lets you offload files in a snap. -
Works with Windows and Mac, USB-C or USB-A
Designed to work with both Windows and Mac, the SanDisk Extreme Portable SSD is equipped with a USB 3.1 Type-C connector and also includes a USB Type-C to Type-C cable and a Type-C to Type-A adapter, meaning it will work with the PCs and Macs of today, tomorrow and yesterday. -
Compact, pocket-sized design
Good things come in small sizes! The SanDisk Extreme Portable SSD delivers high-performance and capacity in a drive that's smaller than a smartphone.
- SanDisk Extreme Portable - SSD - 1 TB - USB 3.1 Gen 2
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.1 Gen 2 - USB-C
- Dust-proof, water resistant, drop-resistant
- 52.55 mm x 100.8 mm x 9.6 mm
- 69.4 g
- 5-year warranty
- Designed For
- Sony PlayStation 5
- Capacity
- 1 TB
- Interface
- USB 3.1 Gen 2
- 52.55 mm
- 100.8 mm
- 9.6 mm
- 69.4 g
Performance
- Internal Data Rate
- 1000 MBps
Expansion & Connectivity
- 1 x USB 3.1 Gen 2
- OS Required
- Windows 10 or later, Apple macOS 13 or later, PlayStation 5 system software
- IP65
- Shipping Width
- 10.7 cm
- Shipping Depth
- 3.3 cm
- Shipping Height
- 12.7 cm
- Limited warranty - 5 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Designed For
