Sandisk Enterprise Z400S 128GB mSATA SATA6Gb/s SSD
Quicklinx: BZBVWS00 Mfr#: SD8SFAT-128G-1122
COST EFFECTIVE AND RELIABLE HDD REPLACEMENT
The SanDisk Z400s is a cost effective SSD designed to replace HDDs in computing platforms. On par with HDD pricing, it can outperform HDDs by a factor of 20, while providing 5 times the reliability at 1/20th the power consumption.
The Z400s is highly versatile and can accommodate a wide range of platforms with its variety of form factors and capacities. It is available in 2.5" 7mm cased, M.2 (2242 & 2280), and mSATA form factors with capacities from 32GB up to 256GB.
The Z400s has also been validated for use in several of the top OEM platforms in the industry, demonstrating its endurance and ability to sustain high-volume transactions. Its solid-state design means there are no moving parts, making it shock-resistant and much more reliable than traditional HDDs, which translates into lower total cost of ownership (TCO) and a better end-user experience.
Low Power
The Z400s utilizes breakthrough SanDisk technology that optimizes power consumption, making it one of the lowest power consuming SSDs at 30mW for average power. This increases the amount of usable hours per battery charge, which is essential for modern mobile devices.
TCO
SanDisk SSDs are more reliable than HDDs, which can improve total cost of ownership (TCO) by reducing downtime due to hard drive failures. They also offer lower latency and greater read/write speeds over traditional HDDs, so users may experience a noticeable improvement in responsiveness. IT departments can extend the useful life of their PC inventory by upgrading the HDDs to the Z400s SSD, thus prolonging replacement cycles and maximizing asset value.
  • Reduce TCO and maximize ROI
    The SanDisk Z400s SSD can improve total cost of ownership (TCO) by reducing downtime and service requests due to hard drive failures. Its solid-state design means there are no moving parts, making it shock-resistant and much more reliable than traditional HDDs.
  • Endurance
    The Z400s is able to sustain a high volume of transactions, making it well-suited for POS systems, ATMs, and other embedded platforms that handle frequent transactions.
  • Low power
    Its low power characteristics mean it generates very little heat, making the Z400s perfect for green and fan-less designs.
SanDisk Z400s - SSD - 128 GB - SATA 6Gb/s
Solid state drive - internal
128 GB
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, DEVSLP SATA low power mode, Windows WHCK certified
29.85 mm x 50.8 mm x 3.82 mm
5 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
128 GB
mSATA
SATA 6Gb/s
29.85 mm
50.8 mm
3.82 mm
5 g
Performance
SSD Endurance
72 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
520 MBps (read) / 180 MBps (write)
4KB Random Read
30000 IOPS
4KB Random Write
40000 IOPS
Reliability
MTBF
1,750,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
mSATA
Power Consumption
50 mW (active) , 1600 mW (read) , 1900 mW (write)
UL, TUV, VCCI, BSMI, FCC, KC
Package Type
Retail
Limited warranty - 3 years
70 °C
