Sandisk Cruzer Ultra Flair 32GB USB 3.0
Quicklinx: DQ75WS00 Mfr#: SDCZ73-032G-G46
Capacity: 32GB
Interface: USB 3.0
£5.33 ex VAT
£6.39 inc VAT
The SanDisk Ultra Flair USB 3.0 flash drive moves your files fast. Spend less time waiting to transfer files and enjoy high-speed USB 3.0 performance of up to 150MB/s . With transfer speeds to drive up to 15 times faster than standard USB 2.0 drives , you can transfer a full-length movie in less than 30 seconds . Its durable and sleek metal casing is tough enough to handle knocks with style. And, with password protection, you can rest assured that your private files stay private . Secure your files in style with the SanDisk Ultra Flair USB 3.0 flash drive.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
  • Fly through file transfers
    Experience high-speed USB 3.0 performance of up to 150MB/s1 with the SanDisk Ultra Flair USB 3.0 flash drive. Transfer files faster than standard USB 2.0 drives.
  • Stylish and tough
    With a durable metal case, the SanDisk Ultra Flair USB 3.0 flash drive is both sleek and ready to handle unexpected knocks.
  • Password-protect your files
    Share your movies or music, but rest assured that private files can stay private. Easy-to-use password protection lets you limit who sees certain files.
SanDisk Ultra Flair - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Encryption Algorithm
128-bit AES
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
SanDisk SecureAccess, SanDisk RescuePRO Deluxe
Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 10
Microsoft Certification
Compatible with Windows 7
5-year warranty
Intel Next Unit of Computing 12 Pro Kit - NUC12WSKi3
USB flash drive
Storage Capacity
32 GB
128-bit AES
Read Rate
Up to 150 MB/s
Interface Type
USB 3.0
Password protection, metal body
Software Included
Limited warranty - 5 years
13.21 mm
42.42 mm
6.6 mm
45 °C
Capacity: 32GB
Interface: USB 3.0
Brand: Sandisk
