The SanDisk Ultra Flair USB 3.0 flash drive moves your files fast. Spend less time waiting to transfer files and enjoy high-speed USB 3.0 performance of up to 150MB/s . With transfer speeds to drive up to 15 times faster than standard USB 2.0 drives , you can transfer a full-length movie in less than 30 seconds . Its durable and sleek metal casing is tough enough to handle knocks with style. And, with password protection, you can rest assured that your private files stay private . Secure your files in style with the SanDisk Ultra Flair USB 3.0 flash drive.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
                Fly through file transfersExperience high-speed USB 3.0 performance of up to 150MB/s1 with the SanDisk Ultra Flair USB 3.0 flash drive. Transfer files faster than standard USB 2.0 drives.
                Stylish and toughWith a durable metal case, the SanDisk Ultra Flair USB 3.0 flash drive is both sleek and ready to handle unexpected knocks.
                Password-protect your filesShare your movies or music, but rest assured that private files can stay private. Easy-to-use password protection lets you limit who sees certain files.
- SanDisk Ultra Flair - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 16 GB
- Encryption Algorithm
- 128-bit AES
- Localisation
- Latin America, Asia Pacific, Middle East, Africa, Europe
- Software Included
- SanDisk SecureAccess, SanDisk RescuePRO Deluxe
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 10
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- 128-bit AES
- Localisation
- Read Rate
- Up to 130 MB/s
- Interface Type
- USB 3.0
- Password protection, metal body
- Software Included
- OS Required
- Limited warranty - 5 years
- 13.21 mm
- 42.42 mm
- 6.6 mm
- 0 °C
- 45 °C
