Sandisk Cruzer Blade USB FlashDrive 64GB
Quicklinx: BD21WS00 Mfr#: SDCZ50-064G-B35
Capacity: 64GB
Interface: USB 2.0
More than 50 In Stock
£12.25 ex VAT
£14.70 inc VAT
The 64GB Cruzer Blade USB Flash Drive may look small, but it has all the space you need to store and share tunes, pictures and home videos – or your presentations and spreadsheets – whenever you want. Despite storing 64GB in a compact and contoured design, the Cruzer Blade USB Flash Drive is barely half the size of most USB Flash Drives. It makes sure that your private files stay protected, with the password protection and encryption  offered by SanDisk SecureAccess software.
  • The capacity you need to store more
    64GB Cruzer Blade USB Flash Drives give you plenty of headroom, just in case. Even with Full HD  video and high resolution images hungry for storage space, you have ample space for storing and sharing the videos, photos and music you love and the work you need to do..
  • Small but perfectly formed
    The 64GB Cruzer Blade USB Flash Drive is one of the smallest in our range at just over 4cm long – and at 2.50g, it is also incredibly light – making it superbly easy to take around with you. Fit the USB Flash Drive comfortably in the palm of your hand, slide it into a pocket or hang it from your keychain..
  • Stay protected with SanDisk
    SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption . This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping..
  • Compatibility
    The Cruzer Blade Flash Drive is optimised for laptops and devices with USB 2.0 ports..
  • Reassurance with performance
    SanDisk develops and engineers its USB Flash Drives to maximise reliability, so you can count on your 64GB Cruzer Blade USB Flash Drive to store your important files.You can enjoy yourself or work away with total peace of mind. 64GB Cruzer Blade USB Flash Drives are backed by a five-year limited warranty..
SanDisk Cruzer Blade - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
64 GB
Encryption Algorithm
128-bit AES
Enclosure Colour
Black, red
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
64 GB
128-bit AES
Enclosure Colour
Black, red
Interface Type
USB 2.0
Password protection
Software Included
Limited warranty - 5 years
Capacity: 64GB
Interface: USB 2.0
Brand: Sandisk
