Sandisk Cruzer Blade - USB flash drive - 16 GB - Hi-Speed USB
USB Range
Quicklinx: 78CZWS00 Mfr#: SDCZ50-016G-B35
The 16GB Cruzer Blade USB Flash Drive may look small, but it has all the space you need to store and share tunes, pictures and home videos – or your presentations and spreadsheets – whenever you want. Despite storing 16GB in a compact and contoured design, the Cruzer Blade USB Flash Drive is barely half the size of most USB Flash Drives. It makes sure that your private files stay protected, with the password protection  and encryption offered by SanDisk SecureAccess software.
  • The capacity you need to store more
    16GB Cruzer Blade USB Flash Drives give you plenty of headroom, just in case. Even with Full HD video and high resolution images hungry for storage space, you have ample space for storing and sharing the videos, photos and music you love and the work you need to do.
  • Small but perfectly formed
    The 16GB Cruzer Blade USB Flash Drive is one of the smallest in our range at just over 4cm long – and at 2.50g, it is also incredibly light – making it superbly easy to take around with you. Fit the USB Flash Drive comfortably in the palm of your hand, slide it into a pocket or hang it from your keychain.
  • Stay protected with SanDisk
    SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption . This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping.
  • Compatibility
    The Cruzer Blade USB Flash Drive is optimised for laptops and devices with USB 2.0 ports.
  • Reassurance with performance
    SanDisk develops and engineers its USB Flash Drives to maximise reliability, so you can count on your 16GB Cruzer Blade USB Flash Drive to store your important files.You can enjoy yourself or work away with total peace of mind. 16GB Cruzer Blade USB Flash Drives are backed by a five-year limited warranty.
SanDisk Cruzer Blade - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
16 GB
Interface Type
USB 2.0
Limited warranty - 5 years
