Speedy data transfers
With a read rate of 400 MB/s, the SanDisk Creator allows for rapid access to files, enhancing productivity and minimizing wait times during transfers. -
Generous storage capacity
Offering 512 GB of storage space, this USB flash drive ensures ample room for documents, photos, videos, and other important data. -
Convenient portability
Equipped with a key ring loop, the drive can easily be attached to keychains, bags, or lanyards, allowing for quick and convenient access to files on the go. -
Robust compatibility
The SanDisk Creator features a USB-C 3.2 Gen 1 interface, ensuring fast and reliable connections with a wide range of devices. -
Reliable operating conditions
Designed to function optimally in temperatures ranging from 0°C to 45°C, ensuring that the drive can operate effectively in varied environments.
 - SanDisk Creator - USB flash drive - 512 GB
- Product Type
 - USB flash drive
- Interface Type
 - USB-C 3.2 Gen 1
- Storage Capacity
 - 512 GB
- Software Included
 - Adobe Photoshop Lightroom (3 months trial)
- OS Required
 - Android 8.0 (Oreo) or later, Apple MacOS 12.0 or later, Microsoft Windows 10 or later
 - 5-year warranty
- Product Type
 - USB flash drive
- Storage Capacity
 - 512 GB
- Read Rate
 - Up to 400 MB/s
- Interface Type
 - USB-C 3.2 Gen 1
 - Key ring loop
- Software Included
- OS Required
 - Limited warranty - 5 years
 - 16 mm
 - 45.8 mm
 - 11.8 mm
 - 10.8 g
- Shipping Width
 - 13.4 mm
- Shipping Depth
 - 101.6 mm
- Shipping Height
 - 152.4 mm
 - 0 °C
 - 45 °C
