High-speed performance
With read rates of up to 400 MB/s, this flash drive ensures quick data transfers, allowing users to move large files without delay. -
Ample storage capacity
The 256 GB storage space provides room for files, documents, images, and videos, making it suitable for both personal and professional use. -
Portable design
Equipped with a key ring loop, this USB flash drive can be easily attached to keychains or bags, facilitating portability and easy access. -
Temperature resilience
Operating effectively within 0°C to 45°C, this drive is designed to perform well in diverse environments, ensuring reliability in various conditions. -
Versatile connectivity
The USB-C 3.2 Gen 1 interface allows for compatibility with devices that support USB-C, streamlining the connection process.
- SanDisk Creator - USB flash drive - 256 GB
- Product Type
- USB flash drive
- Interface Type
- USB-C 3.2 Gen 1
- Storage Capacity
- 256 GB
- Software Included
- Adobe Photoshop Lightroom (3 months trial)
- OS Required
- Android 8.0 (Oreo) or later, Apple MacOS 12.0 or later, Microsoft Windows 10 or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 256 GB
- Read Rate
- Up to 400 MB/s
- Interface Type
- USB-C 3.2 Gen 1
- Key ring loop
- Software Included
- OS Required
- Limited warranty - 5 years
- 16 mm
- 45.8 mm
- 11.8 mm
- 10.8 g
- Shipping Width
- 13.4 mm
- Shipping Depth
- 101.6 mm
- Shipping Height
- 152.4 mm
- 0 °C
- 45 °C
