High storage capacity
With a capacity of 4 TB, this external hard drive enables users to store a large volume of data, including videos, photos, and documents, without running out of space. -
Fast data transfer
The internal data rate of 2000 MBps allows for rapid data transfers, which is essential for ensuring an efficient workflow during high-demand tasks. -
Durable design
Meeting IP65 standards, this drive is both water-resistant and dust-resistant, providing reliable performance in various environments for creative professionals. -
Versatile connectivity
Equipped with a USB-C port and supporting USB 3.2 Gen 2x2 interfaces, connectivity is enhanced through quick and versatile options, including a USB-C cable and a USB-C to USB-A adapter. -
High-speed interface
The external hard drive features an interface speed of 20 Gbps, ensuring quick and efficient data access and transfer across different devices.
- SanDisk Creator Pro - SSD - 4 TB - USB 3.2 Gen 2x2
- Solid state drive - external (portable)
- Capacity
- 4 TB
- Interface
- USB 3.2 Gen 2x2 - USB-C
- Data Transfer Rate
- 20 Gbps (USB 3.2 Gen 2x2)
- Water resistant, dust-resistant
- 57.83 mm x 110.8 mm x 10.31 mm
- 77.5 g
- 5-year warranty
- Capacity
- 4 TB
- Interface
- USB 3.2 Gen 2x2
- 57.83 mm
- 110.8 mm
- 10.31 mm
- 77.5 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 2000 MBps (read) / 2000 MBps (write)
Expansion & Connectivity
- 1 x USB 3.2 Gen 2x2 - 24 pin USB-C
- Software Included
- Adobe Creative Cloud (1 month membership)
- OS Required
- Windows 10 or later, Apple macOS 14 or later
- Cables Included
- 1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
- IP65
- Shipping Width
- 10.3 cm
- Shipping Depth
- 13.6 cm
- Shipping Height
- 3.45 cm
- Limited warranty - 5 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
