Efficient Performance
With an internal data rate of 2000 MBps, the SanDisk Creator Pro ensures quick access and transfer speeds for various files, making it suitable for tasks that require high performance. -
Robust Protection
Designed with an IP65 rating, this external hard drive resists both water and dust, providing peace of mind when storing valuable data in diverse environments. -
Versatile Connectivity
Featuring a USB-C port and including a USB-C to USB-A adapter, this drive connects seamlessly to a wide range of devices for ease of use and compatibility. -
Ample Storage Capacity
Offering 2 TB of storage space, the SanDisk Creator Pro enables users to store a large number of files, making it perfect for creatives and professionals alike. -
Secure Design
With a robust solid state drive format, this external hard drive provides reliable performance and durability, reducing the risk of data loss due to physical damage.
 - SanDisk Creator Pro - SSD - 2 TB - USB 3.2 Gen 2x2
 - Solid state drive - external (portable)
- Capacity
 - 2 TB
- Interface
 - USB 3.2 Gen 2x2 - USB-C
- Data Transfer Rate
 - 20 Gbps (USB 3.2 Gen 2x2)
 - Water resistant, dust-resistant
 - 57.83 mm x 110.8 mm x 10.31 mm
 - 77.5 g
 - 5-year warranty
- Capacity
 - 2 TB
- Interface
 - USB 3.2 Gen 2x2
 - 57.83 mm
 - 110.8 mm
 - 10.31 mm
 - 77.5 g
Performance
- Interface Transfer Rate
- Internal Data Rate
 - 2000 MBps (read) / 2000 MBps (write)
Expansion & Connectivity
 - 1 x USB 3.2 Gen 2x2 - 24 pin USB-C
- Software Included
 - Adobe Creative Cloud (1 month membership)
- OS Required
 - Windows 10 or later, Apple macOS 14 or later
- Cables Included
 - 1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
 - IP65
- Shipping Width
 - 10.3 cm
- Shipping Depth
 - 13.6 cm
- Shipping Height
 - 3.45 cm
 - Limited warranty - 5 years
 - 0 °C
 - 45 °C
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 85 °C
