SanDisk Creator Pro - SSD - 1 TB - USB 3.2
Quicklinx: J04QWS00 Mfr#: SDSSDE81C-1T00-G25
Capacity: 1TB, 1TB
Interface: USB 3.2 Gen 2x2
Type: External hard drive
14 In Stock
£101.66 ex VAT
£121.99 inc VAT
Marketing description is not available.
  • Robust storage capacity
    With a spacious 1 TB capacity, this solid state drive accommodates large files including videos, high-resolution images, and extensive projects.
  • High-speed performance
    Achieve data transfer speeds of up to 2000 MBps, streamlining your workflow and allowing for rapid access to important files.
  • Durable design
    Constructed to withstand adverse conditions, this drive is both water-resistant and dust-resistant, making it a reliable choice for outdoor and on-the-go usage.
  • Advanced connectivity
    Equipped with USB-C and supporting USB 3.2 Gen 2x2 technology, this hard drive delivers quick data transfer rates, enhancing compatibility with modern devices.
  • Wide temperature range
    Operates effectively in a range of temperatures, ensuring dependable performance whether in hot or cold environments.
SanDisk Creator Pro - SSD - 1 TB - USB 3.2 Gen 2x2
Solid state drive - external (portable)
1 TB
USB 3.2 Gen 2x2 - USB-C
Data Transfer Rate
20 Gbps (USB 3.2 Gen 2x2)
Water resistant, dust-resistant
57.83 mm x 110.8 mm x 10.31 mm
77.5 g
5-year warranty
1 TB
USB 3.2 Gen 2x2
57.83 mm
110.8 mm
10.31 mm
77.5 g
Performance
Interface Transfer Rate
Internal Data Rate
2000 MBps (read) / 2000 MBps (write)
Expansion & Connectivity
1 x USB 3.2 Gen 2x2 - 24 pin USB-C
Software Included
Adobe Creative Cloud (1 month membership)
Windows 10 or later, Apple macOS 14 or later
1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
IP65
Shipping Width
10.3 cm
Shipping Depth
13.6 cm
Shipping Height
3.45 cm
Limited warranty - 5 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Capacity: 1TB
Capacity: 1TB
Brand: Sandisk
