Durable metal body
The metal body of the SanDisk Creator Phone Drive ensures longevity, making it a reliable option for everyday use while providing resistance against wear and tear. -
Ample storage capacity
With 256 GB of capacity, this USB flash drive accommodates extensive data, allowing users to store numerous files, media, and applications without worry. -
High-speed data transfer
Enjoy fast data transfers with read speeds of up to 90 MB/s, which helps minimize waiting times when moving files between devices. -
Wide compatibility
Designed to work seamlessly with various devices, the USB-C and Apple Lightning interfaces make it easy to connect and transfer files across platforms. -
Temperature resilient
This drive functions efficiently within a temperature range of 0°C to 45°C, providing flexibility for use in different environments and conditions.
 - SanDisk Creator Phone Drive - USB flash drive - 256 GB
- Product Type
 - USB flash drive
- Interface Type
 - USB-C / Apple Lightning
- Storage Capacity
 - 256 GB
- Software Included
 - Adobe Photoshop Lightroom (3 months trial)
- OS Required
 - Apple MacOS 12.0 or later, Microsoft Windows 10 or later, Android, Apple iOS 13 or later
 - 2-year warranty
- Product Type
 - USB flash drive
- Storage Capacity
 - 256 GB
- Read Rate
 - Up to 90 MB/s
- Interface Type
 - Metal body
- Software Included
- OS Required
 - Limited warranty - 2 years
 - 5 mm
 - 15.2 mm
 - 8.7 mm
 - 20.3 g
- Shipping Width
 - 9.6 mm
- Shipping Depth
 - 101.6 mm
- Shipping Height
 - 152.4 mm
 - 0 °C
 - 45 °C
