SanDisk Creator Phone Drive - USB flash drive - 256 GB
Quicklinx: J04XWS00 Mfr#: SDIXD0N-256G-GN6TP
21 In Stock
£49.16 ex VAT
£58.99 inc VAT
Marketing description is not available.
  • Durable metal body
    The metal body of the SanDisk Creator Phone Drive ensures longevity, making it a reliable option for everyday use while providing resistance against wear and tear.
  • Ample storage capacity
    With 256 GB of capacity, this USB flash drive accommodates extensive data, allowing users to store numerous files, media, and applications without worry.
  • High-speed data transfer
    Enjoy fast data transfers with read speeds of up to 90 MB/s, which helps minimize waiting times when moving files between devices.
  • Wide compatibility
    Designed to work seamlessly with various devices, the USB-C and Apple Lightning interfaces make it easy to connect and transfer files across platforms.
  • Temperature resilient
    This drive functions efficiently within a temperature range of 0°C to 45°C, providing flexibility for use in different environments and conditions.
USB flash drive
Interface Type
USB-C / Apple Lightning
Storage Capacity
256 GB
Software Included
Adobe Photoshop Lightroom (3 months trial)
Apple MacOS 12.0 or later, Microsoft Windows 10 or later, Android, Apple iOS 13 or later
USB flash drive
Storage Capacity
256 GB
Read Rate
Up to 90 MB/s
Interface Type
Metal body
Software Included
5 mm
15.2 mm
8.7 mm
20.3 g
Shipping Width
9.6 mm
Shipping Depth
101.6 mm
Shipping Height
152.4 mm
45 °C
Interface: USB-C / Apple Lightning
Brand: Sandisk
