Efficient data transfer
The drive features a USB 3.2 Gen 2 interface with a speed of 10.0 Gbps, allowing for quick data transfers and ease of use. -
High storage performance
Designed as an external solid state drive, it offers an internal data rate of 1000 MBps, providing fast access to files and documents. -
Robust compatibility
With exFAT formatting, this drive supports various operating systems seamlessly, including compatibility with Apple Time Machine for easy backups. -
Versatile connection options
The product includes a USB-C port and comes with both USB-C and USB-C to USB-A cables, making it adaptable to different devices. -
Suitable for diverse environments
The drive performs well across a range of temperatures, from -20°C to 60°C for storage and operates efficiently from 0°C to 35°C.
- SanDisk Creator Desk Drive - SSD - 8 TB - USB 3.2 Gen 2
- Solid state drive - external (desktop)
- Capacity
- 8 TB
- Interface
- USB 3.2 Gen 2 - USB-C
- Data Transfer Rate
- 10.0 Gbps (USB 3.2 Gen2)
- Apple Time Machine compatible, exFAT formatted
- Power Source
- Included AC adapter
- Enclosure Colour
- Blue gradient
- 9.91 cm x 9.91 cm x 4.02 cm
- 249.6 g
- 3-year warranty
- Capacity
- 8 TB
- Interface
- USB 3.2 Gen 2
- 9.91 cm
- 9.91 cm
- 4.02 cm
- 249.6 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 1000 MBps
Expansion & Connectivity
- 1 x USB 3.2 Gen 2 - 24 pin USB-C
- Power Source
- Software Included
- Adobe Creative Cloud (1 month membership)
- OS Required
- Windows 10 or later, Apple macOS 10.14 or later
- Cables Included
- 1 x USB-C cable - external , 1 x USB-C to USB-A cable - external
- Enclosure Colour
- Blue gradient
- Shipping Width
- 13.6 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 6.7 cm
- Limited warranty - 3 years
- 0 °C
- 35 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
