SanDisk Creator - flash memory card - 128 GB - SDXC UHS-II
Quicklinx: J056WS00 Mfr#: SDSDXEP-128G-GNCIS
£41.66 ex VAT
£49.99 inc VAT
Marketing description is not available.
  • High-speed performance
    With a read rate of 280 MB/s and a write rate of 100 MB/s, this SDXC UHS-II memory card enables quick access and efficient data transfers, ideal for multitasking and heavy file usage.
  • Versatile compatibility
    Designed to work seamlessly with various devices, this memory card accommodates a wide range of applications, making it suitable for both amateur and professional creators.
  • Dedicated write protection
    Equipped with a write protection switch, this memory card prevents accidental overwriting of files, ensuring the integrity of your data with simple functionality.
  • Generous storage capacity
    The 128 GB storage capacity provides ample room for storing high-resolution videos, images, and documents, making it a practical choice for content creators.
  • Reliable speed class
    Classified as Video Class V60 and UHS-II U3, this memory card delivers the performance required for recording high-quality video content without interruptions.
Flash memory card
SDXC UHS-II Memory Card
Storage Capacity
128 GB
Speed Rating
Video Class V60 / UHS-II U3 / Class10
Software Included
RescuePRO Deluxe (2 years download), Adobe Creative Cloud (1 month membership)
Flash memory card
Storage Capacity
128 GB
Speed Class
Read Rate
Up to 280 MB/s
Write Rate
Up to 100 MB/s
Write protection switch
Software Included
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
1.67 g
Type: SDXC UHS-II Memory Card
SD Speed Class: Video Class V60 / UHS-II U3 / Class10
Brand: Sandisk
