High-speed performance
With a read rate of 280 MB/s and a write rate of 100 MB/s, this SDXC UHS-II memory card enables quick access and efficient data transfers, ideal for multitasking and heavy file usage. -
Versatile compatibility
Designed to work seamlessly with various devices, this memory card accommodates a wide range of applications, making it suitable for both amateur and professional creators. -
Dedicated write protection
Equipped with a write protection switch, this memory card prevents accidental overwriting of files, ensuring the integrity of your data with simple functionality. -
Generous storage capacity
The 128 GB storage capacity provides ample room for storing high-resolution videos, images, and documents, making it a practical choice for content creators. -
Reliable speed class
Classified as Video Class V60 and UHS-II U3, this memory card delivers the performance required for recording high-quality video content without interruptions.
 - SanDisk Creator - flash memory card - 128 GB - SDXC UHS-II
- Product Type
 - Flash memory card
- Form Factor
 - SDXC UHS-II Memory Card
- Storage Capacity
 - 128 GB
- Speed Rating
 - Video Class V60 / UHS-II U3 / Class10
- Software Included
 - RescuePRO Deluxe (2 years download), Adobe Creative Cloud (1 month membership)
 - Limited lifetime warranty
- Product Type
 - Flash memory card
- Storage Capacity
 - 128 GB
- Speed Class
- Read Rate
 - Up to 280 MB/s
- Write Rate
 - Up to 100 MB/s
- Form Factor
 - Write protection switch
- Software Included
 - Limited warranty - lifetime
 - 24 mm
 - 32 mm
 - 2.1 mm
 - 1.67 g
