Large storage capacity
With a 1 TB storage, users can store countless photos, videos, and files without the worry of running out of space. -
Fast data transfer speeds
The read rate of 190 MB/s and write rate of 130 MB/s enable quick data transfers, allowing for seamless editing and sharing. -
Robust environmental protection
The SanDisk Creator card is designed to resist damage from shocks, water, temperature variations, and X-ray exposure, safeguarding crucial data. -
Versatile compatibility
This memory card comes with a microSDXC to SD adapter, making it compatible with a wide variety of devices such as cameras, drones, and smartphones. -
Optimized for performance
With Speed Class A2 and UHS-I U3 ratings, this memory card ensures smooth loading of apps and high-quality video capture.
- SanDisk Creator - flash memory card - 1 TB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 1 TB
- Speed Rating
- A2 / Video Class V30 / UHS-I U3
- Included Memory Adapter
- microSDXC to SD adapter
- Software Included
- Adobe Photoshop Lightroom (3 months trial)
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 1 TB
- Speed Class
- Read Rate
- Up to 190 MB/s
- Write Rate
- Up to 130 MB/s
- Form Factor
- Temperature-proof, magnetic-proof, waterproof, shockproof, wear-out proof, X-ray-proof, drop-proof, humidity-proof
- Software Included
- Limited warranty - lifetime
- 10.92 mm
- 14.99 mm
- 1.02 mm
- 0.26 g
