Sandisk 64GB Ultra Micro SDXC UHS-I 48MB/s
Quicklinx: BHBZWS00 Mfr#: SDSQUNB-064G-GN3MN
SanDisk Ultra microSDHC /microSDXC UHS-I cards are ideal for Android and other smartphones and tablets.Take better pictures and Full HD video with SanDisk Ultra microSD UHS-I cards . Take advantage of transfer speeds of up to 48MB/s to save time moving photos and videos from the card to your computer.With Class 10 video ratings you'll be ready to capture high quality Full HD video (1080p). SanDisk Ultra microSD UHS-I cards are waterproof, temperature-proof, X-ray proof, shock-proof and magnet proof and come with a seven-year warranty .
  • The ideal companion for Android smartphones and tablets
    The cards' additional storage means you can take more photos and videos without worrying about running out of space.
  • Class 10 Speed Rating for Full HD Video Capture
    Dependable high speed allows you to shoot Full HD video (1080p) and high quality photos .
  • Move your files, fast
    Ultra-fast transfer speed of up to 48MB/s means that you spend less time waiting for files to transfer.
  • Easily Back Up Your Favorite Media with the SanDisk Memory Zone App
    The SanDisk Memory Zone app, available on the Google Play store, makes it easy to view, access, and back up all of your files from your phone's memory in one convenient place . You can set the app to off-load files from your device's internal memory to your memory card automatically.
SanDisk Ultra - flash memory card - 64 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
Class 10
Software Included
SanDisk Memory Zone
Microsoft Certification
Compatible with Windows 7
7 years warranty
Flash memory card
Storage Capacity
64 GB
Speed Class
Class 10
Read Rate
Up to 48 MB/s
Shockproof, waterproof, X-ray-proof, temperature-proof
Software Included
SanDisk Memory Zone
Limited warranty - 7 years
15 mm
11 mm
Thickness
1 mm
-25 °C
85 °C
