Sandisk 64GB Ultra Dual USB 3.0 Flash Drive
Quicklinx: C6ZMWS00 Mfr#: SDDD2-064G-g46
Quickly and easily transfer your files between OTG-enabled Android smartphones and tablets and PC and Mac computers.  Simply connect the SanDisk Ultra Dual USB Drive 3.0 to the micro-USB port of your Android device and move up to 64GB of content to the drive, freeing up space to add photos, videos, songs, and more. The high-speed USB 3.0 connector enables you to transfer files rapidly, at up to 130MB/s, from drive to computer. Spend less time waiting to transfer a full-length movie to the drive than with a standard USB 2.0 drive .The SanDisk Memory Zone app (available on Google Play ) helps you manage your phone's or tablet's memory , making it easy to move, view, copy, or backup your photos and videos to the drive, so you're always ready to take more videos and pictures on the go.
  • Simple to move files
    The SanDisk Ultra Dual USB Drive 3.0 has a micro-USB connector at one end, a high-speed USB 3.0 connector at the other. To transfer your favourite files, simply plug the micro-USB connector to your Android smartphone or tablet and start transferring the music, videos, photos and other files you want to move. Easily share file from drive to other OTG-enabled Android devices. Or quickly copy files from drive to computer with high-speed USB 3.0 performance.
  • The capacity you want
    If you want to keep your files handy, the SanDisk Ultra Dual USB Drive 3.0 has plenty of room, up to 64GB, for loads of photos, tracks, videos or even massive work files ready for using and sharing.
  • Manage your content
    With the SanDisk Ultra Dual USB Drive 3.0, looking after your content is straightforward. The SanDisk Memory Zone application , available on Google Play , lets you organise files stored on internal and external phone memory for management, viewing, copying and backup.
SanDisk Ultra Dual - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0 / micro USB
Storage Capacity
64 GB
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
SanDisk Memory Zone
Apple MacOS X 10.6 or later, Android, Microsoft Windows Vista / 7 / 8
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 130 MB/s
Interface Type
USB 3.0 / micro USB
USB On-The-Go compatible
Plug and Play
Software Included
SanDisk Memory Zone
Limited warranty - 5 years
11 mm
19.8 mm
36.6 mm
45 °C
