The SanDisk Extreme 500 portable SSD is less than half the size of your smartphone and delivers up to 4x the speed of an external hard drive .Get to work in seconds, transfer big videos and photo libraries at up to 415MB/s (for 120GB and 240GB) and up to 430MB/s (for 480GB)-a speed that external hard drives can only dream about. Designed for durability and style, this drive is amazingly compact and has no moving parts to break.Solid state technology offers reliable, responsive, high-performance storage for photographers and videographers who capture and carry lots of big media files. When you care about your day's work, it pays to make the SanDisk Extreme 500 your portable storage drive.
Speed counts
Who wants to spend precious time waiting, waiting - for big files to transfer and open? The SanDisk Extreme 500 portable SSD speeds up the pace of business for fast-moving photographers and videographers. Time is money after all. -
Trust a tough guy
Bump it. Drop it. Leave it in the hot or cold. The SanDisk Extreme 500 portable SSD is built tough to resist shocks, vibrations and temperature extremes. -
Protect your privacy
SanDisk SecureAccess software uses 128-bit encryption to keep private files from prying eyes. -
Stay cool
Hard drives generate heat. They can't help it, it's how they're built. The SanDisk Extreme 500 portable SSD is a cool and quiet companion and a solid partner on even the busiest of days.
- SanDisk Extreme 500 Portable - solid state drive - 480 GB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 480 GB
- Interface
- USB 3.0
- Shock resistant, vibration dampening, heat-resistant, software encryption, 128-bit AES
- 7.569 cm x 1.067 cm x 7.569 cm
- 78.9 g
- Localisation
- Australia, New Zealand, Latin America, Asia Pacific, Middle East, Africa, Europe, Americas
- 3-year warranty
- Capacity
- 480 GB
- Interface
- USB 3.0
- 7.569 cm
- 1.067 cm
- 7.569 cm
- 78.9 g
Performance
- Internal Data Rate
- 415 MBps (read) / 340 MBps (write)
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type A
- Software Included
- SanDisk SecureAccess
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Windows 8, Windows 8.1
- Localisation
- Limited warranty - 3 years
- 0 °C
- 45 °C
