Sandisk 32GB Extreme Compact Flash Card
Quicklinx: C18XWS00 Mfr#: SDCFXSB-032G-G46
Type: CompactFlash Card
Capacity: 32GB
SD Speed Class: [N/A]
Hurry, only 3 left in stock!
£64.36 ex VAT
£77.23 inc VAT
Ideal for use with mid-range to high-end DSLR cameras and HD camcorders, the SanDisk Extreme CompactFlash memory card delivers first-rate read/write speeds to catch fast action shots and enable quick file transfers. This memory card features Video Performance Guarantee (VPG-20) to deliver a minimum sustained recording data rate of 20MB/s to support high-quality Full HD video (1080p) recording. Take advantage of burst-mode photography with the card's write speeds of up to 567X and enjoy efficient workflow with its transfer speeds up to 120MB/s.
  • Up to 85MB/s write speeds for exceptional shot to shot performance
    With write speeds of up to 85MB/s, the SanDisk Extreme CompactFlash memory card adds to your mid-range to-high-range DSLR's performance during burst-mode shooting, rapid shots, and RAW plus JPEG capture. The card records photos almost instantly, ensuring you will catch your best shot. Read speeds of up to 120MB/s make transferring images to your computer fast and simple .
  • Includes VPG-20 specification for professional-grade video capture
    Featuring a Video Performance Guarantee (VPG-20) profile specification, the SanDisk Extreme CompactFlash memory card can keep up with the steep memory demands of professional video equipment such as HD camcorders. The card's VPG-20 ensures data transfer between card and camera with a sustained data recording rate of 20MB/s for a smooth and unbroken video stream. You'll be able to record in resolutions as high as 1080p without skipped frames.
  • Durable design
    SanDisk Extreme CompactFlash memory card is designed to handle whatever life throws at you. This card is backed by rigorous stress, shock, and vibration testing and includes RTV silicone coating for protection against shock and vibration. It operates in nearly any climate, with a functioning temperature range of -13 to 185 degrees Fahrenheit.
  • High storage capacity
    The SanDisk Extreme CompactFlash memory card offers plenty of space to store high-resolution photos and Full HD videos.
SanDisk Extreme - flash memory card - 32 GB - CompactFlash
Flash memory card
CompactFlash Card
Storage Capacity
32 GB
Speed Rating
567x
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
32 GB
Speed Rating
567x
Read Rate
Up to 120 MB/s
Write Rate
Up to 85 MB/s
CompactFlash Card
UDMA 7 Mode, Video Performance Guarantee (VPG)-20
Limited warranty - lifetime , Germany: limited warranty - 30 years , Canada: limited warranty - 30 years
-25 °C
85 °C
Capacity: 32GB
Brand: Sandisk
