Reliable, Fast and Plenty of Capacity
The Speed You Need
Sequential read speeds of up to 520MB/s mean faster boot-up, faster application response, faster data transfer and better game-playing than you’ve experienced from your laptop or desktop before.
240GB Capacity
With 240GB capacity, SanDisk SSD Plus gives you plenty of room for your big media files and applications—photos, videos, music, games and more.
Cool and Quiet
With its low-power architecture, the SanDisk SSD Plus places minimal strain on your system's resources. The drive consumes less power and produces less heat than a traditional HDD, easing the burden on your PC's power supply and cooling system. It also runs quietly, so you can enjoy videos and games without distracting background noise.
SanDisk SSD Dashboard monitors drive status
Windows users can check their drive's status in real-time and be alerted to software updates. And it includes third party software offers from Apricorn for cloning onto your new drive, Titanium+ Virus scanner from TrendMicro and Lojack recovery software from Absolute to secure your computer, too.
Please note the Upgrading Kit is NOT included with this purchase
Fast read speeds for less waiting, more doing
Sequential read speeds of up to 520MB/s mean faster boot up, faster application response, faster data transfer and better game playing than you've experienced from your laptop or desktop before. -
SSD resilience, longevity, and quiet
With no moving parts, your SanDisk SSD keeps your data safe even if you drop your notebook or tablet, while also running cooler and quieter than a typical notebook or tablet. It's resistant to vibration and temperature fluctuations. Plus, long battery life means a longer leash and higher productivity for your notebook or tablet, on the go.
- SanDisk SSD PLUS - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- 69.85 mm x 100.5 mm x 7 mm
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 520 MBps
Reliability
- MTBF
- 1,750,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g
