Sandisk 128GB Extreme Go USB3.1 Drive
Quicklinx: D43PWS00 Mfr#: SDCZ800-128G-G46
With write speeds of up to 150MB/s, the SanDisk Extreme Go USB 3.1 Flash Drive lets you quickly copy and go. Up to 35X faster than standard USB 2.0 drives, so you can transfer a full-length 4K movie to the drive in less than 40 seconds . The design keeps the retractable connector protected when not in use, and the included SanDisk SecureAccess software provides password protection of your private files while leaving the rest of the drive available for sharing.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
  • High-speed performance
    With write speeds of up to 150 MB/s, the SanDisk Extreme Go USB 3.1 Flash Drive is 35x faster than standard USB 2.0 drives so you can transfer a full-length 4K movie in less than 40 seconds or 1000 photos in less than 60 seconds.
  • Retractable design
    The USB connector retracts to keep it safe when you're not using it.
  • USB 3.1 enabled, yet backward-compatible
    The SanDisk Extreme Go USB 3.1 Flash Drive is backward-compatible so you can plug it into any USB 2.0 or 3.0 port.
SanDisk Extreme Go - USB flash drive - 128 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
128 GB
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
USB flash drive
Storage Capacity
128 GB
Read Rate
Up to 200 MB/s
Write Rate
Up to 150 MB/s
Interface Type
USB 3.1
Retractable connector
Software Included
70.87 mm
21.34 mm
11.43 mm
18.14 g
35 °C
