Samsung Xpress C410W Colour Laser Printer
PRINT WIRELESSLY AND SHARE EFFORTLESSLY
Quicklinx: BG1HWS00 Mfr#: SL-C410W/SEE
Print wirelessly and share effortlessly with the Samsung Xpress printer. With advanced NFC technology, Wi-Fi Direct and powerful compatibility, all it takes is a simple tap.
Text, graphs or images - the C410W helps you print anything in brilliant quality that meets even the highest expectations. Its 600 x 600 dpi can be enhanced to an impressive 2400 x 600 dpi by varying the dots size and the position of the dot itself. This means you can print more detail and have smoother and sharper images.
  • A printer that makes all smartphones smarter
  • One touch Eco button
    Just one push of the ECO button and you can save on toner, paper, and energy. Print multiple pages on one sheet, change color to greyscale or skip blank pages.
  • One touch WPS button
    Connect quickly and securely to your wireless network with the touch of a button, via the one-touch WPS (Wi-Fi Protected Setup).
  • Enjoy quality printouts
    Samsung's unique ReCP (Rendering Engine for Clean Page) technology improves the overall quality and vibrancy of your color printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
  • Polymerized toner
    The polymerized toner has smaller and more uniform particles than conventional toner. Meaning, your printouts will have crisper lines and more vivid colors - helping avoid any paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
  • Ergonomic design
    Its ergonomic design with ebony brown and ice grey color creates a modern and elegant work environments.
Samsung Xpress C410W - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
9.85 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 152.4 mm
Max Media Size (Custom)
216 mm x 355.6 mm
Print Speed
Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 4 ppm - colour - A4 (210 x 297 mm) , Up to 4 ppm - colour - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
USB 2.0, LAN, Wi-Fi(n)
300 MHz
RAM Installed (Max)
32 MB
Language Simulation
SPL-C
Media Type
Labels, plain paper, recycled paper, cotton paper, thick paper, thin paper, glossy paper
Total Media Capacity
150 sheets
Media Handling
150-sheet paper cassette
Monthly Duty Cycle (max)
20000 pages
Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.8
1-year warranty
38.2 cm x 30.9 cm x 21.1 cm
Printer Type
Printer
Print Speed
Wireless
2400 x 600 dpi
2400 x 600 dpi
First Print Out Time B/W
14 sec
First Print Out Time Colour
26 sec
Language Simulation
SPL-C
Media Handling
300 MHz
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 152.4 mm
216 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76 x 152.4 mm
Media Weight
60 g/m² - 220 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
50 sheets
Duty Cycle
20000 pages
1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 500 pages ISO/IEC 19798
Power supply - internal
290 Watt
Power Consumption Stand by
60 Watt
Power Consumption Sleep
1.4 Watt
Limited warranty - 1 year
Sound Emission (Operating)
48 dBA
38.2 cm
30.9 cm
21.1 cm
9.85 kg
