Samsung Xcover 550 3G GSM Android Phone
Quicklinx: BGCHWS00 Mfr#: SM-B550H#BTBM
  • microSDHC
  • Android
What's in the Box:
  • Samsung Xcover B550 - Dark Silver (SM-B550H)
  • Mains Charger
  • Headphones
  • User Manual
Display
Buy the rugged Samsung Xcover B550 from Handtec. It features a 2.4 inch screen with a simple resolution QVGA (240 x 320 pixels). The 2.4 inch screen is designed so that contacts, SMS and images are clearly visible to you.The Samsung Xcover B550 is perfect for making calls and sending SMS.
Design
Your Samsung Xcover B550 comes with a traditional keypad. It is specially designed for all those who do not want to use touch screen phones. Moreover, the keypad makes it more durable to be used in tough conditions.Moreover, an additional feature of your Samsung Xcover B550 is the IP67 rating. This makes the device water and dust proof. It can stay in one meter of water for up to 30 minutes. Samsung has dressed your Xcover B550 in a shell that with stands bumps and drops.
Camera
Your Samsung Xcover B550 comes with a 3 mega pixel camera making it useful for taking pictures while you are at a construction site. Moreover, bluetooth is included so that you can share these images with other devices.
Technical Specifications:
General:
  • Network: GSM 850 / 900 / 1800 / 1900, HSDPA 900 / 2100, undefined
  • Chipset: SC7703A
Multimedia:
  • Camera: 3.15 MP, 2048 x 1536 pixels, LED flash
  • Audio MP3-WAV-eAAC+ player
  • Games: Downloadable
  • Java: MIDP 2.0
  • Headphone jack: 3.5 ??
  • Playing video: MP4/H.263 player
  • The front camera: No
Calls:
  • Ringtones Type Vibration; Polyphonic, MP3
Communication:
  • Interfaces, Bluetooth, NFC, USB
  • Internet access: GPRS, EDGE
  • Satellite navigation: GPS
Memory and processor:
  • Supported memory cards: microSD 32 GB
  • Memory card slot: Yes
  • Built-in Memory: 128 MB
  • RAM:128 MB
Display parameters:
  • Screen Type TFT
  • Diagonal Screen "2.4"
  • Image Size240 x 320
  • The number of pixels per inch (PPI):167
Battery:
  • The type of battery used: Li-Ion
  • Capacity of the battery used: 1300 mah
Multimedia:
  • Camera Resolution (pixels): 2048 x 1536
  • The flash: LED flash
Communication:
  • Browser: WAP 2.0/xHTML
Samsung Galaxy Xcover 550 - dark silver - 3G feature phone - GSM
3G feature phone
Manufacturer Model Number
SM-B550H
Display
LCD display - 320 x 240 pixels - 2.4" - TFT
FM radio, LED flashlight
460 MHz (dual-core)
RAM 128 MB
Supported Memory Card
microSDHC slot - up to 16 GB
Main Camera
3.1 Megapixel focus: automatic
Service Provider
Not specified
Bar Rugged
Wireless Interface
Bluetooth
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack
Talk Time
Up to 480 minutes
Protection
Shockproof, waterproof
Dark silver
56.2 mm x 13.95 mm x 129 mm
120.4 g
0.78 W/kg (head) , 0.44 W/kg (body)
SAR Category (Belgium)
B
Feature phone
SM-B550H
Bar - Rugged
Protection
Integrated Components
56.2 mm
13.95 mm
129 mm
120.4 g
Body Colour
Dark silver
B
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
3G
Service Provider
Not specified
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
Wireless Interface
Bluetooth 3.0
Bluetooth Profiles
FTP, HFP, HSP, OPP, A2DP, AVRCP
Media Player
Supported Digital Audio Standards
WAV, AAC, MP3, MIDI, M4A
Supported Digital Video Standards
MPEG-4, 3GP
Clock Speed
460 MHz
Processor Core Qty
Dual-core
RAM
128 MB
Supported Flash Memory Cards
microSDHC - up to 16 GB
Main Camera
Sensor Resolution
3.1 Megapixel
Focus Adjustment
Automatic
Light Source
LED light
Display
LCD display
TFT
Diagonal Size
2.4"
Display Resolution
320 x 240 pixels
Colour Depth
262,144 colours
Connector Type
Headset jack - mini-phone 3.5mm , USB
1500 mAh
Talk Time
480 minutes
Run Time Details
Talk (WCDMA): up to 480 min
IP67
Power adapter
