The Galaxy XCover 5 is a rugged yet sophisticated device designed to handle demanding jobs while meeting the needs of an increasingly mobile workforce. Engineered for the field and factory, the Galaxy XCover 5 combines durability with comfort for a product that is sleek and easy to hold, yet rugged enough to withstand tough work environments. It's built to power today's mobile business with improved touch sensitivity for use with gloves and comes with an easy-to-charge, replaceable battery for all-day productivity.
Built for tough environments
The Galaxy XCover 5 is equipped with various features to handle demanding jobs and activities. Enhanced shock absorption enables the Galaxy XCover 5 to withstand drops of up to 1.5 meters and IP68-rated dust and water resistance means it can be submerged in over a meter of water for longer than 30 minutes with complete protection against dust. And, as professionals in the field are required to wear gloves due to health and safety precautions, the Glove Touch feature increases touch sensitivity allowing users to operate the device while wearing gloves for quick and convenient use. In addition to being physically built for lasting durability devices must protect sensitive information critical to business operations. The Galaxy XCover 5's hardware is protected by Samsung Knox, the company's defense-grade security platform offering true end-to-end protection with security embedded across every single layer of the device, from the chip all the way up to the apps. -
Great performance
Equipped with the powerful Exynos 850 processor, 4GB RAM and up to 64GB internal storage, the Galaxy XCover 5 has the power to keep up with the stringent demands of your business. The long-lasting, replaceable 3,000mAh battery also supports fast charging through USB and POGO pins so you can spend less time plugged in and more time on the task at hand. -
Professional-grade camera
The Galaxy XCover 5 comes equipped with a single 16MP (F1.8) rear camera that provides impeccable sharpness making it effortless to capture professional-grade images and videos. The Live Focus feature allows the subject of your shot to stand out and the 5MP (F2.2) front camera is ideal for video conferencing. Furthermore, the inclusion of Samsung Knox Capture also allows enterprise-grade scanning right on your phone at a competitive value, without compromising device performance. -
Convenient features
The Galaxy XCover 5 is also packed full of other convenient features that will aid users' work and outdoor activities. The LED flashlight on the rear of the phone next to the camera can be used like a torch light, assisting your vision in darker environments. The Galaxy XCover 5 also comes equipped with an NFC chip allowing the phone to be used as a wallet or transportation card, making it ideal for professionals who use public transport to commute to work.
- Samsung Galaxy Xcover 5 - Enterprise Edition - black - 4G smartphone - 64 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G525F/DS
- Display
- LCD display - 1480 x 720 pixels - 5.3" - PLS TFT
- Processor
- 2 GHz (8-core)
- Memory
- RAM 4 GB / 64 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Main Camera
- 16 Megapixel - f/1.8 - focus: automatic
- Front Camera
- 5 Megapixel f/2.2
- Service Provider
- Not specified
- Form Factor
- Rugged
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1860 minutes
- Protection
- Water-resistant, dust-resistant
- Black
- 71.6 mm x 9.2 mm x 147.1 mm
- 172 g
- Specific Absorption Rate (SAR)
- 0.699 W/kg (head) , 1.272 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-G525F/DS
- Form Factor
- Touch - Rugged
- Protection
- 71.6 mm
- 9.2 mm
- 147.1 mm
- 172 g
- Body Colour
- Black
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 26, Band 28, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, gyro sensor, RGB sensor, geomagnetic sensor, light sensor
- Additional Features
- Samsung KNOX
Media Player
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Clock Speed
- 2 GHz
- Processor Core Qty
- 8-core
- RAM
- 4 GB
- Internal Memory Capacity
- 64 GB
- User Memory
- 46.8 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.2
Main Camera
- Sensor Resolution
- 16 Megapixel
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Light Source
- Dual LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
- Live Focus
Display
- LCD display
- Technology
- PLS TFT
- Diagonal Size
- 5.3"
- Display Resolution
- 1480 x 720 pixels
- Display Format
- HD+
- Colour Depth
- 16.7 million colours
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm , Pogo Pin
- Capacity
- 3000 mAh
- Talk Time
- 1860 minutes
- Run Time Details
- Talk: up to 1860 min , Active online usage (LTE): up to 13 hrs , Active online usage (Wi-Fi): up to 13 hrs , Playback (video): up to 13 hrs , Playback (audio): up to 56 hrs
- IP68, MIL-STD-810H
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
