Experience crystal clear dialog with a dedicated center speaker on the Soundbar. It provides balanced sound from one end of the bar to the other and angles the sound so that voices seem to emanate from the screen. The Soundbar was designed with 6 separate speakers, each with its own dedicated amplifier, to provide clear and accurate sound. The Wireless Surround Kit lets you easily expand your surround sound system, and without the tangle of wires. Together with your Soundbar, you can create a 5.1 channel system for a true surround sound experience. TV SoundConnect helps bring your home entertainment system together with your TV with ease and without the clutter of wires. You'll be able to enjoy all your content instantly with clearer, more impactful sound. With its convenient wireless design, the subwoofer is incredibly easy to set up anywhere, quickly giving you the freedom to enjoy supersonic bass quality and a fully natural sound experience. Feel the sound and get into the action with stunningly realistic HD audio. It preserves the quality and richness of the original sound using 192 kHz/24-bit sampling. Now you can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up, and stream your music. The Soundbar uses Bluetooth for easy wireless connections to other devices. Enjoy music from your mobile or PC in top audio quality anywhere, no strings attached.
Clearer voices with the center speaker
Experience crystal clear dialog with a dedicated center speaker on the Soundbar. It provides balanced sound from one end of the bar to the other and angles the sound so that voices seem to emanate from the screen. -
Clear sound from 6 built-in speakers
The Soundbar was designed with 6 separate speakers, each with its own dedicated amplifier, to provide clear and accurate sound. -
Build a surround sound system wirelessly
The Wireless Surround Kit lets you easily expand your surround sound system, and without the tangle of wires. Together with your Soundbar, you can create a 5.1 channel system for a true surround sound experience. -
Use TV SoundConnect to link components
TV SoundConnect helps bring your home entertainment system together with your TV with ease and without the clutter of wires. You'll be able to enjoy all your content instantly with clearer, more impactful sound. -
Experience even more powerful bass
With its convenient wireless design, the subwoofer is incredibly easy to set up anywhere, quickly giving you the freedom to enjoy supersonic bass quality and a fully natural sound experience. -
Bluetooth power on
Now you can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up, and stream your music. -
Get real with HD audio
Feel the sound and get into the action with stunningly realistic HD audio. It preserves the quality and richness of the original sound using 192 kHz/24-bit sampling. -
Mobile sound with Bluetooth connection
- Samsung HW-K551 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 3.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 340 Watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, LPCM, OGG
- Speaker System Details
- 1 x sound bar 180 Watt , 1 x subwoofer 160 Watt 3 Ohm
- Speaker Details
- Sound bar - stereo x 2 - 60 Watt - 10% THD - 6 Ohm - active , Sound bar - centre channel - 60 Watt - 10% THD - 6 Ohm - active
- Silver
- Built-in Decoders
- Dolby Digital, DTS decoder, DTS Digital Surround
- Sound Effects
- Surround Sound Expansion
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- USB-host
- Enclosure Colour
- Silver
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 340 Watt
- Maximum Sampling Rate Supported
- 192 kHz (WAV, FLAC)
- Amplifier
- Integrated
- Sound Effects
- Bluetooth
- Built-in Decoders
- Audio Formats
- Controls
- EQ mode selector, power on/off, volume
- Speakers Included
- 1 x sound bar - 180 Watt - wall-mountable - wireless , 1 x subwoofer - 160 Watt - 3 Ohm - wireless
- Speaker Details
- Driver Details
- Subwoofer: subwoofer driver - 7"
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (5 pin Micro-USB Type B) , Audio line-in , Digital audio input (optical) (TOS Link)
- Included Accessories
- Remote control, wall mounting bracket
Sustainability Information
- ENERGY STAR Certified
- Power Source
- AC power adapter
- 53 Watt
- Dimensions (WxDxH) / Weight Details
- Sound bar: 1.0105 m x 8.75 cm x 5.4 cm / 2.6 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
